Another tire question
I have a F250 Crew cab 4X4 PSD. I need to get a set of not too aggressive all terrain tires. The issue is a lot of A/T tires tend to give you a spongy ride in the rear when towing. My '09 had a set of Hankook Dynapro ATM's and the rear axle felt like it was all over the place. Is any body here towing a little heavy (11,000lbs) with a set of A/T tires, and what brand are you running? I am looking at the Cooper Discoverer A/T3 or Nitto Terra Grappler. I am looking more for towing stability than looks. Thanks....
The Discoverer A/T3 is A popular tire with good ratings but also a more aggressive tread and had to set of Nitto Terra Grapplers on my F350 when I got it and wouldn't recommend them for anything other then dry pavement use.....and now have Trail grapplers and tow significantly heavier than that and is still incredibly stable... Are you sure it's the tires?
That's about the same opinion I have of Nitto's now, the Terra's were ridiculously bad for traction in anything but dry pavement and the Trail's or not anywhere near as good for traction compared to any MT tire that I have owned.
The T/A KO is a great tire. Just a little to aggressive tread pattern. Looking for more of a crossover tire because the only dirt driving I do is to the campsite with the toy hauler.
The tread may be more like what you are looking for.
PSP5980
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
13
09-17-2008 03:27 PM
