P0194 fuel rail sensor erratic
2008 6.4 Got this code yesturday and the truck idled rough and died started it back up and it does it intermittent is this possibly just a sensor change under the valve cover or fuel pump ? I was going to change the sensor tomorrow and go from there. This is the only code I could pull fuel rail pressure was right at 5750 at ideal and went up to 7-8000 just giving it a little fuel the voltage for the sensor is bouncing from 1.18 - 1.22 volts running koeo .50
Resalto.jones
1999 to 2016 Super Duty
05-14-2015 04:14 PM
