Breakaway Switch In Michigan
Hi Everyone,
Does a trailer that carries over 3000 pounds in Michigan need a breakaway switch that works? I bought a trailer that the brakes work but the breakaway switch cable is gone. Just seeing if I need to fix it right away or work on some other projects on it first.
Thanks,
Calvin
Thanks,
Calvin
I don't see anything that even requires a breakaway switch under our MCL's.
Michigan Legislature - Section 257.705
I checked a number of other sections related to RV's and found nothing. Nothing in the pdf on recreational doubles either.
I will probably reinstall it just after I fix the lights, grease the hubs, and check the brakes. My only concern is I hook and unhook the trailer multiple times a week, so I may forget that it is tethered and pull the breakaway...
Thanks for that. I looked around and did not find anything of importance either. They make it so hard to find a specific requirement.... I found a rv site that said it had to be either safety chains or breakaway but I would not feel safe without chains.
Before computers, I had to look up MCL's in very large books (and then check for changes in subsequent years books). Life is a lot easier, trust me.
I also looked at 4 different RV sites. 3 mentioned either no breakaway switch required, or didn't speak of one at all. 1 site said required (but no citation).
Not saying its not a good idea. Just don't think it is "required".
Good luck and safe travels.
Yea its only $6 plus shipping... If the switch has had the cable pulled for quite sometime, I would assume at least 6 months. Would the switch still be ok or would it need to be replaced?
Guess I'll have to check and see if the brakes are working. When I pulled it home, the electric brakes seemed to work. The wiring is pretty messed up so It maybe cut out and the breakaway is completely disabled...
Towing World Official Website
Pretty good source
This website says breakaway for 3K trailers If I read it right. Does not mean it is accurate though.
Pretty good source
Firstly, a good rule of thumb, not necessarily a rule of law, is that if the trailer is large enough to have included electric brakes, it pretty much must have a safety measure in place (aka, a breakaway system) to stop the trailer should it be separated from the tow vehicle.
In regards to actually frying the wiring for the brakes by leaving the pin pulled on your breakaway system, that is not even an issue unless someone hooked an enormously large battery to the breakaway system AND you had a shorted brake puck or dead shorted wire to your wheel ends. Reason being is that the pucks will only draw as much amerage as they can from the power source and most, if not all, battery setups installed for breakaway purposes are not large enough or hold enough capacity to cook the pucks. They burn up and cause an open in the circuit instead of burn up and cause a dead short.
In reality, if your trailer has had the breakaway removed, it was because the system was not operating properly for some reason (like the owner had no idea how to maintain it or that you need to change out the battery regularly to keep the system working properly) and deleted that part of the system for their own liking. There are lots of resources online talking about how these systems are designed, how they work, how to spec a system if you are installing one from scratch and how to troubleshoot one that is inop. I can even answer questions about them from my 100's of hours of fixing systems after doofuses have destroyed them by neglect or willful maliciousness.
Bottom line - if your trailer has electric brakes, it was probably manufactured with a breakaway system. Not completely sure but I believe that falls under federal DOT requirements. The goal is to have that system activate in emergent need and stop the trailer quickly, then hold the brakes applied for a brief period before the battery goes dead making sure that the trailer stays put once stopped. I believe that the specified time is 15 minutes before the battery goes dead.
