Injector O-ring advice
Im changing out dummy plugs and standpipes and while im waiting for those to come in, Im going to inspect my injector o rings (top). Is it worth just changing them all out as a preventative measure or should i just replace as necessary? Ive read and watched the videos that say if the top part of the injector orings are toast, then the nipple cup o ring on the oil rail could be suspect for causing the top injector ring to go bad. I dont suspect the nipple cup seals but if its worth it, I would like to change out the top o rings on the injectors while i have it opened.
05 model
Thanks!
05 model
Thanks!
I had the drivers side valve cover off of my '03 and did the top o-rings. It's not that hard, just takes a little time and patience. No need to take the injectors or the top clip out. I will tell you the passenger side will take more time back near the A/C box.
I did have the nipple cup o-rings replaced as a PM measure by a reputable shop near me.
FORD 6.0L ~Replacing the Top Injector Seal Without Removing Injector or C-Clip ~Easy! - YouTube
I watched the videos you posted in https://www.ford-trucks.com/forums/1...ole-story.html You did such a good job with that. I'll try to rep you.
Thats what i was curious about. Whether or not to go ahead and replace them as a preventative measure. Thanks!
Thanks!
Thanks!
Sorry no I don't I wish I did this and the crush washers the ones I have been getting come with every oring in and out on the injector I will attach a picture of them also I just got another set last week thatnalso has all of them. The seal on the right I just pulled out of an injector that was used for probably 3000 miles so you have a comparrison
