Front End Alignment question. I'd like your opinion...
Received 3,090 Likes
on
About DIY alignments, my F-250 (Dana 50) has been down for 4 days now for DIY alignment, ball joints, front axle shaft U-joints, wheel bearing lube and brakes. I haven't been working on it continuously but I've spent a LOT of time on it. Some of the delay has been due to parts stores selling me the wrong parts but part of the delay is that it's not such an easy task.
I got a set of very useful Specialty Products Company 24130 bushings that are adjustable for both caster and camber. They come with a chart showing how to set them for various caster and camber adjustments. They are intended for professionals and they assume you know what you're doing. Whoever invented them is a lot smarter than I am and I spent some time just sitting down, reading the sparse instructions and scratching my head.
I do my own work partly because I've been doing it since I was 16 and I just can't break the habit. The other reasons are that I'm a certified cheapskate and last but not least I am fed up with the poor work done by commercial shops.
I think my point is that getting the alignment correct is not a simple project, is taking a LOT longer than I thought and your time may be a lot better spent with your family or other activities.
About the caster range, for my '96 the allowable spec is 2 to 6 degrees, however, there is also a spec for the split between the two. In other words, it is not OK for one side to be 2 and the other side 3, even though both sides are within the allowable range. Some guys recommend setting the drivers side caster a little bit more positive than the passenger side in order to help compensate for crowned roads.
I replaced the leaf spring bushings and axle pivot bushings with urethane bushings first and that alone fixed 90% of the camber issues. I also installed some Firestone air bags and they really compensate for sagging springs. I can adjust the camber back to factory spec just by adjusting the air pressure in the bags. They seem to hold air pressure pretty good over time. I know someone isn't going to be able to resist correctly telling me that it would've been cheaper and simpler to go to a Dana 60, but that train has left the station. I've invested too much time and money into this Dana 50 to ever give up on it. And, knock on wood, the urethane bushings seem to have solved most all of the camber problems.
Bob
Bob
Bob
on
i do not take vehicles that need parts for alignment. they are repaired before they go, because why pay for it to be done twice?
exactly the $75 is for the alignment only. but since the front end is basically new on anything i take there i do not have to pay for add on parts.
I know adjusting caster and camber on 2 wheel drive trucks is easy as you said. On a Super Duty 4x4, you need special ball joints to do that. No shop will include that type of repair in their $75.00 advertised front alignment price. Even tougher on my 97 F-Superduty that I used to own. It was a solid I-beam with kingpins.
KillyMcGee
03-27-2018 08:30 AM
88grandmarquis
05-07-2003 08:24 PM
