5.4 3V expert advice needed to replace phasers vs whole rebuild?
#31
Low oil pressure is often a sign of worn bearings. I'd do some investigating before changing the oil pump, it may not be worth it. How many miles are on the engine?
#32
I am going to pull the sender and put gauge on it. I don't have a dry place to work and it's been raining a lot. The best guess is that something is loose and drifting over the oil pick up. Cold, the dash gauge jumps up to normal and suddenly drops to zero in 10-30 seconds. Each time I shut down and restart, it drops sooner and finally does not come up at all. Half hour later it will again come up to normal a few seconds.
#33
#34
#37
So just went to the garage that I have been going to forever...they put 12v straight to VCT solenoid and that freed the left phaser loose and they took it for a 10 mile drive....ran fine....so we decided to do an engine flush with this stuff called BG engine flush and will add a can of BG to the fresh oil....and see what happens....sounds like sludge or something got in the phaser and locked it up....
#40
I would be cautious running any additive in the oil. The timing tensioners are oil driven and the seals are already prone to leaking. Putting some snake oil in the oil may only make things worse.
#41
Meanwhile, the oil pump is also providing oil to the cylinder heads, lubricating the cams and the followers. Usually if there is a problem with the VCT system due to low oil volume, there is likely to be damage to the valve followers as well. This is why it is recommended to inspect them.
In a word - no.
#42
Found this thread after getting a 06 Navigator (125K) with codes and slightly rough sounding engine but runs and drives good. Stealership tested it and said phasers and VCT solenoids are good but that the timing has jumped. From what little I have read I assume the guides are worn and the slack allowed the timing to jump. Truck is sitting in meanwhile and thinking of getting the chains, guides, tensioner, water and oil pump done. I am not used to OHC engines so need to read up on cam followers since I read they can wear and need replacement.
#43
Sounds familiar, bought my 06 Expedition with 80k miles, idled rough but ran great...until it threw the timing chain through the right valve cover. Guides were gone, literally disintegrated. The timing chain had worn grooves into the timing cover there was so much slack. Do it all now, including the phasers, there is no band-aid for whats coming if you keep running it like that and you only want to do it once.
#44
Come to find out one of the screens on the less than a year old solenoid was torn....they are ford factory ones and come to find out they have a 2 year warranty...good thing I keep my paperwork..so Ford gave me a new one and put the info in the computer. So I have one new one and one that is a year old...Truck runs fine....so how does the screen being torn affect the engine performance....I know it has to do with oil pressure and oil flow...so with the screen torn...is it getting to much non-filtered oil through that area..?
#45
