Shock question
Shock question
I read the many preferences expressed on the forum for shocks and it seems the Bilstein 5100's are a fan favorite. I looked the 5100''s up and they have the front shocks (0 to 2.5 in lift) but there is no rear shock with that designation--only 3 to 5 inches. I did the spring swap on the front and RAS on the back and I may put F350 blocks on the rear to raise the rear 1.5 inches to level the X a bit more. Can anyone shed some light on which shocks you should use?? Thanks
Just out of curiosity....have you been looking at excursion specific shocks only? You can use the ones designed for an F250 also and will mostly likely find a wider ranger of shocks that will work for you. I had to do the same searching for my Rancho 9000XLs. The way the back shocks hook up is slightly different but it basically uses a metal tube that runs thru the eye at the top of the rear shock
Nice topic, I mistakenly ordered the 5100's for the rear of my truck. I have SRW C codes and stock blocks. I installed them and they are too long, I may have felt them bottom out once while towing. I can either switch to 4600s or just add the F350 block to the rear (~1.25") and raise the front up accordingly. I'll probably raise it up as ever since I put the Vs up front, I'd like a bit more ride height. I think the F350 blocks will net me about 2.75" from stock based on my notes.
A few more thoughts...
Before the 5100s I had Rancho 9000s, they rode nice on the highway and controlled well over a single event but did not control well on broken pavement. The front 5100s do a much better better job. The rear 5100s are a bit stiff for low speed, through subdivisions and the rear Ranchos were better there. Towing, the 5100s are by far better in my application.
Lastly I meant to call Bilstein and see if the valving was different between the 4600 and 5100 shocks because if it were different for low speed, I might try them. But even if I stay with the 5100s in the rear and raise the truck up, I can live with their low speed valving.
Hope this helps.
Hope this helps.
Hope this helps.
Hope this helps.
jav_eee
1999 to 2016 Super Duty
06-27-2017 10:03 PM
