Trailer brake question
I pulled this link from the E trailer FAQ section. I think it addresses your question.
https://www.etrailer.com/question-13954.html
I tried adjusting the brakes like the first said when I put them on. Apparently I didn't do a good job of this. So I am gonna go with the let them adjust themselves and see what happens. I have so slowly travelled roads around me. I think I will just take it for a spin and just go slow and apply the brakes on and off a lot. We will see how this works.
Steve
Sorry. Not trying to be obsessed. Just am thinking new brakes equal stopping power I had before. And that's not happening yet. I guess I just need to chill, take it for some drives and see what happens. Hopefully adjusting and start working before my truck brakes are toast
As I said before, check the heat or temperature per axle after driving a bit. Heat will destroy your shoes, not to mention, overheat the bearings.
Drive for 5 minutes and check the temperature of each hub, relative to the others.
It will tell you if one or more hub is over tightened.
Adjust and do it again, keeping the temps similar and yet feeling the effects of the brakes when applied. Again, expect about 160-165 degrees after a session.
Then you felt the brakes were not working very well, but gradually they started working again and now are as noisy as they were initially?
There is not much in that system. You have a pair of shoes rubbing against a drum when the brakes are activated by the brake controller.
Now that they are noisy again, would it make sense to raise one wheel at a time and see which one or ones is making the noise.
If any wheel is running so hot it is destructing, you can certainly smell it and you will not need an IR gun to measure the heat. It will feel plenty warm to the touch.
Certainly a puzzler.
Steve
Most of this advice here, comes from previous pitfalls, trying to avoid what we've already experienced.
I did the feel test. The driverside rear is on fire when I stop. The other three wheels are good to go. Don't understand how one wheel can adjust its self back to that point.
#28
#29
I'd start by backing off the drum adjuster wheel, ensuring you go the correct direction. Again as others have stated, raise the wheel off the ground and spin it while adjusting, ensuring you just have a very fine amount of drag or noise.
Buy an IR tester. Pretty cheap anywhere these days and safe another quick brake job.
#30
