vin decode
If built before that it will have a Rating plate on the glove box door and the rest of the information will be stamped on the firewall. The 18,710 is a borderline number for KC.
Y block wasn't introduced until 1954 in US production, so if your 51 has that engine, it's been transplanted.
Check to see if you can find a series of numbers and letters stamped directly into the upper part of the firewall. That could give you more info about your truck. Post them here if you find them.
Also, check the frame to make sure it has the same SERIAL number
If it's a 48-50, post the Serial (Vin's didn't exist back then) number here https://www.ford-trucks.com/forums/4...ut-off-27.html
If it's a 1951-52 post it here https://www.ford-trucks.com/forums/1...l-numbers.html
If it's 53-56 just start a new thread with the Serial number.
What year are you looking to decode? If it's a 1948-56 THIS is the best place, to the best of my knowledge there is no 'site' to decode them, but we have several members with the information available.
DavidSa
10-02-2021 01:02 PM
Fordcab
05-09-2007 11:01 PM
55 F-100 PAUL
08-26-2003 12:47 AM
