Glow plug rely and controller
Ok update here. Talked to PO. He thought it was just glow plugs. Asked him if he was still in contact from owner he got it from. Gave me info. This owner test glow plugs. He says everything was a ok with glow plugs in fact pretty new. But it needs a controller and power for controller.
Any preference for what controller relay I should pick up? And anyone got a diagram off hand for the whole setup? Thanks.
Received 3,106 Likes
on
what you have on the passenger side fender is the proper starter relay.
what he butchered into the glow plug circuit is an older starter solenoid without the controller, and it will not work.
starter relays/solenoids are body ground, and will not work unless grounded.
glow plug relays are internally grounded. the two large lugs are for power in/power out. the two small terminals are for trigger power. one gets 12 volts, the other gets grounded.
DmanNC
08-27-2014 03:34 PM
