Smallest wheel for winter wheels?
Old 10-28-2015, 11:28 AM
ngng's Avatar
ngng
ngng is offline
Looking for the smallest diameter wheel I can run for a set of winter wheels without giving up load capacity. I have a '11 350 SRW with the 20" KR wheels from the factory and tow at max load. I want a set of dedicated winters, and would love to fit something like the Nokians on 18s (275/70/18), or smaller.
From my research, I haven't been able to figure out if a smaller wheel will clear my brakes.
Would love any input you all have.
Old 10-28-2015, 11:29 AM
System's Avatar
System
System is online now
Prolocutor
Received 1,198 Likes on 573 Posts
Lower trim level's come with 17's so they would fit.
Old 10-28-2015, 11:32 AM
ngng's Avatar
ngng
ngng is offline
Brakes are the same on all 350s?
Old 10-28-2015, 11:42 AM
System's Avatar
System
Prolocutor
Yes............
Old 10-28-2015, 11:52 AM
ngng's Avatar
ngng
ngng is offline
Yes............
My other concern is the load rating on the tires,
Current tires, Michelin LTX M/S2, LT275/65R20 3,750# max load. The 18" Nokians seem closest.
Winter tires,
Blizzak, LT265/70R17 is 3,195# max load
Michelin LTX Winter LT265/70R1 3,196# max load
Nokian Hakkapeliitta LT2 LT265/70R17, 3,200# max load
Firestone Winterforce LT275/70R18 3,640# max load
Nokian Hakkapeliitta LT2 LT275/70R18 3,640# max load
Old 10-28-2015, 11:53 AM
ngng's Avatar
ngng
ngng is offline
Yes............
Thanks, I wasn't completely sure if Ford had an option for larger brakes.
Old 10-28-2015, 12:03 PM
89LX306's Avatar
89LX306
89LX306 is offline
If you are towing heavy on those tires, I would go with the higher weight ratings. Do those tires meet your towing needs? If not, maybe a snow rated all-terrain tire with a higher weight capacity.
Old 10-28-2015, 12:24 PM
ngng's Avatar
ngng
ngng is offline
They're all the same load range. Since these will be winter only, my thinking is that I want pure winter tires. I think the winner is the 18" Nokians here.
Old 10-28-2015, 02:45 PM
Dakster's Avatar
Dakster
Dakster is offline
I wouldn't go smaller than 18" as then you start to lose speed rating too. or at least you have to be cognizant of it. One of the reasons the F450 with the 17" tires have a lower speed limiter set from the factory. Not like I expect you to be going over 80 mph towing - but I like to have more speed rating than I'll ever use. Kind of the same reason I got the F350 over the 150 or even a 250. I'll never be over loaded.
FWIW, I agree with the dedicated severe winter/snow tire philosophy.
Old 10-28-2015, 03:07 PM
smlford's Avatar
smlford
smlford is offline
I have to ask why do you want to go to the smallest wheels?
I can see going down to the 18's as you have more tire choices but the diameter of the tire should be kept the same.
(Fellow Porsche racer here ��)
Old 10-28-2015, 03:14 PM
smlford's Avatar
smlford
smlford is offline
These tires BFG KO2's are winter rated and have a higher load rating...
http://www.tirerack.com/tires/tires....lar=Crew%20Cab
Old 10-28-2015, 04:26 PM
FatOldGuy's Avatar
FatOldGuy
FatOldGuy is offline
3,640 is the same load rating that he listed for the Nokian's. I also like the idea of dedicated winter wheels/tires.
Old 10-28-2015, 08:57 PM
ngng's Avatar
ngng
ngng is offline
That's the same load rating. I'm picking up a set of 18" OEM wheels and have ordered at set of the Hakkapeliittas (which are regarded as the best snow tire available). We'll see how they wear, I do plan on towing the trailer a few times when I'm not in the mountains.
Old 10-28-2015, 08:58 PM
ngng's Avatar
ngng
ngng is offline
I tow at 55-65, I drive at 70
Old 10-28-2015, 09:00 PM
ngng's Avatar
ngng
ngng is offline
Smaller wheels have more tire sizes available, narrower tires handle better in the snow. Same reason I went with 18s on the Porsche
Quick Reply: Smallest wheel for winter wheels?
