Coolant leaks from ontop of thermostat+water pump how to fix?
Old 10-27-2015, 06:14 PM
Theos92vr4's Avatar
Theos92vr4
Theos92vr4 is offline
Hey guys. My 1993 f150 with the straight six so far has been an awesome truck. I started noticing some coolant reside from one of the pipes that comes out of the thermostat, and one that comes out above the water pump. I looked on rockauto to see if maybe these parts where integrated into the thermostat and the water pump, but it seems like they are a separate part.
Can these be replaced? if so, can someone point me in the direction of what they are called, and where to buy them? thanks in advance!
here are some pics, the pipes in question have the green "foam" around them
Old 10-27-2015, 11:18 PM
zemus420's Avatar
zemus420
zemus420 is online now
Here you go I went ahead and edited your pic so I could explain to you better if you have any question just post a reply. Where I say "Looks to be your gasket" I forgot to put it looks like your upper hose may also have a loose clamp. The metal pipe is a Coolant elbow Part# E5TZ-18599-C it may need to be replaced. Hope that helps you out.
Old 10-28-2015, 09:03 AM
Theos92vr4's Avatar
Theos92vr4
Thank you sooo much!!I have been looking for that part # for quite a while and was never able to find anything
sunuvabug
27
06-07-2019 06:47 PM
'88 E-350
10-29-2010 07:46 AM
Shake-N-Bake
03-09-2010 11:59 PM
pminne
11-30-2007 09:54 AM
coops
10-01-2004 09:53 AM
Quick Reply: Coolant leaks from ontop of thermostat+water pump how to fix?
