Just a dumb Ol'man
Even if it's been flashed, it's not exactly plug-and-play. If you're not a member over at "the Nation", you should join up there, and check out the "Torque Pro Android for OBS" thread (or some similar name) in the OBS section there. There's a fair amount of setup to do, but in the end, since you already have a device to install it on, it's cheaper than the "traditional" devices used to communicate with our trucks.
My plug on the truck is a perfect rectangle and is pointed down at the floor
I just went out to the truck and plugged in the OBS thing. I got a red light that says power.
As I plug it in I see a yellow light flash then a green light, only the red light stays on
My I-pad says ...Not connected
I have tried it about 5 times now
Now what???
Now what???
Your truck's made of OSB?.... KIDDING....
Look back over there on PSN, on that thread; maybe there's a member who's gotten Torque Pro to work, who lives near you, and can help you directly with yours. That's the beauty of these forums, even though they're global, you can make local connections.
OSB
It might as well be OSB. That is as far as I have gotten....LMAO
I can not get it to connect to my tablet....I have been hunting for a blue tooth connection for the last 2 hrs on this tablet....None seen
under the torque app it says it is not connected
it does not know the scanner tool.....Vgate Bluetooth scanning tool
I bought this one because I saw pictures of it on this site and PSN
My tablet is a android 4.4.2 ever what that means
(On your tablet go to your Bluetooth settings and find the option to pair with a device)
That is the main issue. I can not figure out how to do that....Been trying all day
looking at youtube...Torque app....settings on I pad
The Ol' Truck is running OK now....But I would like to know what the CEL was on for if it had nothing to do with the vacuum pump going out
OH Well
OH Well
It seems like you are unfamiliar with your tablet, not problems with Torque.
Android 4.4.X is the operating system of your tablet AKA KitKat.
Here are some instructions on how to pair a new Bluetooth device on Android KitKat
HP Tablets - Connecting to Bluetooth Devices (Android KitKat, Jelly Bean) | HP® Customer Support
When you are searching for devices, make sure the OBDII reader is plugged into the truck and the key is on (don't have the engine running). once it pairs it will ask for a pin it is usually 0000, 1111, or 1234 as cowmilker said.
