Transmission gear oils
So I am looking to change the tranny fluids in my trucks. The '64 F-250 has a 4 speed I think it's a T-98. The '66 F-100 has a ford light duty 3 speed. I'm a little ignorant on the new types of gear oils out there, GL-4 GL-5 ..... What works best in these old trucks?
Thanks. john
Thanks. john
From what I could gleam in the manuals it was 50wt in the four speed and 80wt in the three speed. But then there is all the different ratings and clasifications: limited slip, gl-4, gl-5. I've read in some threads where some of the rated weights are not the same as when the equipment was designed, or are not for use with certain kinds of gears (helical vs.std) Wanted to see what others were using.
I use GL 4 80-90 for both trans and rear axle. Recently change and found a gallon filled both with approx. a cap full to spare.
98 5.4 downgrade to 94 4.6L
I got a 98 f250 5.4 c.o.p, with pat sys. and a 94 Lincoln 4.6l coil pack non pat system I'm over hauling my 5.4 is it possible to put the 4.6 into my truck? so Iv heard u could use the 4.6 block with the heads of the 5.4. Heard their is only a 2 inch diff in the decks.rest was same heads. Values if the same.
fdeeptone
15
03-24-2014 06:20 PM
Mitch1407
03-02-2011 09:54 AM
bhardy501
12-19-2010 12:24 AM
