'06 getting harder to start
I did a search but came up with too many options for this ***!
It's a stock truck that lately does not start on the first crank (cold).
I have a scangauge II and my ficm usually reads 48.0 Volts but occasionally drops to 47.5 but I don't think that's an issue.
Batteries are about 2 years old and I have upgraded my alternator to 185 amps. I have about 10k on my fuel filters as well.
Should I have the batteries load tested first?
Thanks for all the help and this forum!
A quick trick you can also do is spin out the ICP sensor on the passenger side valve cover first thing in the morning before the starter engages for the day. You should see oil wanting to spill out right at the threads.
If you don't, likely you have a leak in the high pressure oil system.
Park nose down and see if it starts easier, if so then the seal for the HPOP. If not, something else like dummy plug. Pull the ICP sensor first thing before starting it, if you see oil in the hole, most likely the drivers side is the issue, not the passenger side (you see oil and it didn't leak out).
Agree. You have a leak, injector o-ring or an o-ring on a dummy plug probably, something small.... that IPR at 23 isn't bad. If it was 24-28 like before, then a bigger leak for sure.
To be clear, though, your 48V reading on the FICM is when the motor is STONE cold, during Key On Engine Off, during the cranking when it isn't immediately starting, and even when it DOES start, yes?
It is harder to start cold for sure. If I restart it within a couple of minutes of shutting down warm it starts right up.
There are 2 ways on a late model:
1: Using an IPR test plug (HHC Diesel or ebay). This is the best test.
2: Testing through the ICP port. This method requires commanding the IPR valve closed using IDS or Autoenginuity, or by feeding it 12 volts from the battery or a special electronic IPR valve closer.
Here is my old video on it. Air testing is about the second half of the video. I'm sure there are better videos out there now.
