Gas Tank Options
Gas Tank Options
Looking to replace the gas tank in my 2005 F250 CC 4X2 SB V10. The 29 gallon OE tank works fine for driving around town but I'm planning on doing a cross country trip with a fifth wheel soon and would like a little better reach between refills. Anyone have any recommendations?
I have a 46-gallon Transfer Flow tank on my 2002. Yes, it was expensive, but it's an excellent quality part and TF's customer service is second to none.
Interestingly enough, I just checked their website and they don't list a replacement tank for your truck, or my truck any more. Maybe give them a call?
The part number for mine is 0800111953.
Transfer Flow has a tank for gas trucks but you are looking at least $2k until you have it shipped.
If you can do without the spare tire and can do the plumbing/electrical you can fit an Excursion tank in place of the spare.
My dads 15' short bed has a 35gal tank and transfer flow can obviously fit a 46gal tank in the space, Ford could have done a lot better than a 29gal tank.
I had these guys build me a custom 30 gallon in bed fuel tank several years ago... It's still working fine... It has it's own fuel pump externally mounted under the truck bed and it's own sending unit to a gauge in my 4 gauge pod on the a-pillar...
It was expensive but cheaper than most others at the time... It transfers fuel into the main tank via a switch on the dash... Works well for me...
Les
Truck Tanks
Les
Truck Tanks
Would be nice to be able to use the Ex tank and the stock tank like the old dual tank setups. 70+ gallons.
on
No, it is a Transfer Flow tank especially made to replace the original gas tank, 47 gallons. If Titan had made a replacement I would have bought it since the Titan is a nylon tank and lighter. The TF is steel and heavier, but that's the only replacement tank available. You can always get an "in-the-bed" tank, but I didn't want one of those. My truck weight went to 8560 which is 460 lbs more than it was before I installed the tank.
