Engine stops running
I have a 2000 F-350 SuperDuty with a 7.3 liter diesel which stops running after about two minutes and does this each and every time I start it. I've drained the filter bowl and change the fuel filter which did not help. I've also noticed the fuel pump solenoid gets extremely hot to the touch. If the culprit is the fuel pump would a pump other than FORD pump work? If so, where can I buy one....
Thanks
Thanks
drjoe171
09-20-2010 06:04 PM
RedBarron89
08-04-2010 07:07 AM
