E350 body on an F150 chassis?
I have a 1992 Ford E350 Quigley 4x4 conversion van. It has also been converted to a wheelchair accessible vehicle, including a lowered floor and lift. Van is in very good shape for the year. But the suspension on the Quigley conversions is extremely rough, which seems to be a common complaint.
I've been looking at doing some suspension upgrade to it, when I found a 2012 F150 crewcab chassis for $2000. Powertrain is all there and in good shape. Supposedly it was stolen and stripped.
My question is, would the econoline body fit on the F150 chassis? Is it a direct bolt-on or is major retrofitting required?
Thanks for looking and hopefully providing some input.
Any thoughts on suspension improvements other than taller springs and longer shocks?
UJOR. They replace the front end with a solid axle and leaf spring. I would have not think going from coil to leaf springs will improve handling, but I guess it is better to have a good Leaf spring set up than a bad one made with coil spring.
It may lift the van too much for your chair lift to work though.
danielzink
09-23-2004 11:09 PM
danielzink
08-22-2004 01:36 AM
