New Engine
New Engine
Just installed a new rebuilt engine in my 1995 F150. I purchased the engine from an Automotive Machine Shop up in Maine. It's only firing on 4 cylinders. I'm going to do a compression test in the morning. The cylinders that are missing are 3754. The engine is firing 2 cylinders then skipping 2 cylinders. Fires 1, no fire on 37, fire 26, no fire 54, fires 8. I am getting spark to all 8 cylinders. Any ideas or opinions before I dig into it in the morning?
Have you been in contact with the machine shop? They will probably have some suggestions since they will have to provide warranty service otherwise at some point. Was it a long block aka "crate motor" with all the trimmings?
Make sure too you've followed carefully all of their requirements to be eligible for warranty service. For example, while this doesn't apply in your case, new water pump and radiator, things like that. Otherwise they might say "too bad so sad".
It is MAF. I did the engine swap myself. I am a mechanic by trade. I was a mechanic in the military, and I worked for Chrysler for 5 years. Only new wires are the spark plug wires. Engine wire harness is all original. I did put a new coil on it.
on
OK good info there. Was the reman engine supposed to be a direct replacement for a '95? Have you tried the old 302 firing order on the plugs? If the motor has a cam with the old firing order in it it still won't run correctly with the spark plugs revised because the injectors are fired sequentially too, but it may run a bit better and then you will know. You then have to decide what action you want to take to fix it.
Did you check timing with spout connector taken off ? I would first be focusing on the timing then go to the next step of SD vs MAF. Factory base setting is probably 10 degrees, most guys here go to 12 to 14 and listen for pinging, then back it off. Actually MAF is the better system so once you get it running right you'll be happier. With MAF you could go with a bigger cam for better performance. I have the opposite problem at the moment ....
Yes, by not removing/pulling the SPOUT connector, you can't set base timing and the PCM continues to adjust.
I pulled my SPOUT this evening and timed my engine to 10 degrees BTC. Shut off the engine. re-inserted the SPOUT, and started the engine back up. It sounded so good. I am a disabled veteran, and I can't do anything else to the truck until I get my next check on the 1st. The next thing to do is to get it legal and take it down for a front end alignment. Anyway, I let it idle for at least half an hour, then drove it around in the yard a little. It started idling way down, and died a couple of times as I was backing it back into the garage. When I start the engine back up, the timing is on 10* BTC and the mark is steady, then sporadically the timing will advance probably 15* more for a few seconds, then back down to 11*. Through all of this, the timing mark is steady.
It may be that the cam is too radical for fuel injection, even MAF systems have limits with a stock computer. If you have a vacuum gage, take a reading at idle. It should be at least 14 inches I believe. Get much lower and things can get thrown off, idle will surge etc. I've seen a stock truck computer run with an e303 cam , but it didn't like it.
Also thank you for your service.
