New Oil Pan & Pump......No Oil Pressure
Hi guys,
I have a '95 E250 Van.
Oil pan was leaking, so we dropped it and while we had it down to replace it, we also figured we'd replace the oil filter as well.
New filter in, new oil pan, new gasket, what could go wrong.
We pulled the distributor, spun the oil pump rod and couldn't get oil pressure. Finally after cracking the oil filter loose and letting g oil pump out of the block, we then tightened up the oil filter and were able to get pressure on the Guage by spinning the pump with a small battery drill.
Did tune-up, plugs, wires, cap, rotor. Start the van and there's no oil pressure. We shut it down, remove oil filter, fill oil filter with oil and restart the motor. Voila, we have pressure.......for a few seconds........then it's gone. Fill the filter again, same story, momentary pressure, then gone.
Not sure where to go from here. Anyone ever experience this before?
I had an engine lose pressure on one of my race cars. I had told my driver previously if he ever loses oil pressure kill the engine instantly regardless of where he is on the track. He did. When we disassembled the engine the only thing we could find was there were TWO gaskets between the pickup and pump. They must have collapsed / compressed over time and allowed the pump to draw in air. Replaced gasket.
Problem solved.
Problem solved.
paul c. w.
13
06-11-2014 12:07 PM
G2IC_Wraith
1983 - 2012 Ranger & B-Series
03-29-2005 08:47 AM
