?s for Mr. Gary lewis - Ford Truck Enthusiasts Forums
Old 10-24-2015, 06:41 PM
arkredneck's Avatar
arkredneck arkredneck is offline
arkredneck is starting off with a positive reputation.
I put the hei dizzy I n the bronco and gave it a big wire like you said and I put the msd Spring kit in the dizzy. I'm curious if I have the vacuum port unhooked and if I rev the engine and look at the timing marks with a timing light they should change right?? It doesn't move until I hook the vacuum line up and then it jumps to 50ish. It does seem to have better Thottle response and more bottom end to it. I haven't opened it up yet it's raining and I'm a chicken. But when i do go to get on it the engine bogs.
Old 10-25-2015, 02:06 AM
SDDL-UP SDDL-UP is online now
SDDL-UP is starting off with a positive reputation.
If the vacuum port is unhooked, the distributor will run whatever you have set for initial timing, and will still pull in the mechanical advance. Mechanical advance only comes in at higher RPM, depending on springs installed, hence the need for vacuum advance.
50 degrees seems really high! I'm no expert, but I'd try 10-12 initial, and 30-32 overall.
Old 10-25-2015, 02:57 AM
Tedster9's Avatar
Tedster9 Tedster9 is offline
Tedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputation
What the engine timing degrees are often referred to as "total" timing actually means initial + mechanical (for V8 usually 36 to 38 is optimum)
But, that's not counting the additional vacuum advance on top of that - so the actual total timing BTDC out on the highway say, at steady part throttle cruise can absolutely reach 50 degrees.
Old 10-25-2015, 08:14 AM
Gary Lewis's Avatar
Gary Lewis Gary Lewis is offline
Gary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant future
Yep, all are right. My guess is that you may not have revved it enough to get the mechanical to come in, so didn't see it. But, when you hooked up the vacuum you must have connected it to manifold vacuum and that gave the engine an additional shot of RPM, which was enough to start bringing the mechanical advance in.
But, I wouldn't connect the vacuum advance to manifold vacuum. Your carb has a ported vacuum source, which means it isn't "on" at idle but comes in quickly thereafter. That's the one you want to use.
Old 10-25-2015, 08:19 AM
arkredneck's Avatar
I recede it pretty high I'd say over 3000 with it all unhooked and nothing. I'll hook it to the ported one.
Old 10-25-2015, 08:21 AM
arkredneck's Avatar
I meant I revved it high. And also on a side note. The throttle return spring came loose while driving and the gas pedal got stuck to the floor that was a new experience
Old 10-25-2015, 08:40 AM
Gary Lewis's Avatar
Well, perhaps the mechanism was jammed until you hooked up the vacuum, and that freed it up. But, it sounds like it is working now, although you haven't said if you've tried it with no vacuum again.
I'll bet that was a wild ride with the throttle floored. Maybe you should put on two springs?
Old 10-25-2015, 09:04 AM
arkredneck's Avatar
What happen was they used one of the carb bolts to hold a bracket to hold the spring and that bracket came loose which let the spring go it's gonna get fixed today. These engines seem to have a lot of torque I hit the brakes and I'm not sure how long they would have held it until they over heated. I'm use to driving 7.3 turbo diesels I have 3 of those right now and that's what I'm use to working on and the torque of these things kinda reminds me of those but not quite as much after the turbo lights up.
Old 10-25-2015, 09:05 AM
arkredneck's Avatar
How do you guys listen for knock with loud exhaust? Is there a sensor you can install with a gauge?
Old 10-25-2015, 09:21 AM
Gary Lewis's Avatar
I don't run loud exhaust. But, it might be possible to add a detonation sensor from a later engine, or maybe there's an aftermarket sensor - I don't know. I just run a fairly quiet Magnaflow muffler and listen for pinging - which usually happens long before detonation.
Old 10-25-2015, 09:28 AM
arkredneck's Avatar
This bronco came with dual flow masters And they kinda have that raspy sound to begin with.
Old 10-25-2015, 09:41 AM
Gary Lewis's Avatar
There are Flowmasters that sound reasonable, and there are those you couldn't pay me to run. Some are mellow and some are awful.
Old 10-25-2015, 06:29 PM
arkredneck's Avatar
I drove it with it hooked up to the ported vacuum and it seems to run good. It does have a bog to it. Also I put a 1" carb spacer and now it seems like the trans doesn't shift the same. Is there suppose to be any kinda spring or a return on the kick down linkage?
Old 10-25-2015, 08:20 PM
Gary Lewis's Avatar
Assuming you have a C6, and you don't have anything in your signature to tell what you have (hint, hint), there's no spring on the kick-down linkage. But, my guess is that you have a vacuum leak around that spacer, and the tranny shifts based on vacuum. So, squirt some brake cleaner around the base of the carb and the spacer. And, that could account for the bog as well.
Old 10-25-2015, 09:31 PM
arkredneck's Avatar
I'll try and work on my signature. I use a app on my phone and it won't let me update the profile and my wife keeps the lap top. I'll check for a vacuum leak. But I figured since I raised the carb an inch it might have threw the linkage out of wack
C-6 transmission gary's1950F1 1948 - 1956 F1, F100 & Larger F-Series Trucks 10 12-11-2015 10:15 PM
aussie 1990 5.8 question scrape 1987 - 1996 F150 & Larger F-Series Trucks 0 08-27-2015 08:15 AM
tired of vacuum advance! The_SnowMan710 Ford Inline Six, 200, 250, 4.9L / 300 12 08-22-2012 01:28 AM
Pre-Lube Cam On Engine That's Been Sitting? Gary Lewis 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 13 06-27-2011 12:42 AM
302 Firing order, HEI upgrade Thanksgiving turkey! 61-UNI 1961 - 1966 F-100 & Larger F-Series Trucks 1 11-29-2009 09:53 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
