HELP! 1989 F250 5.8 Runs great then dies after warm
Hi Guys new to this forum. Figured I try this out and see what I can learn. I know people in these forums are very helpful and I am very appreciative. As I get to know the truck I will be of use to others here to. Thats my goal so with that.....
I just purchased a 1989 F250 with a 5.8 motor. Great truck for its age. Ive owned other Ford trucks in the past and my Dad had them as a kid. Love them.
When I bought the truck from the 2nd owner it had a problem so I bought this truck with the problem figuring with my past knowledge I could fix it. Not the case. When I got the truck it would start fine and run really great but when it got warm it seems it would die and I would have to wait till it was cooled down to start back up and again it would run fine. Well the problem got worse and worse and now it wont run at all. It will run on starter fluid so that leads me immediately to the fuel pumps. I say that plural because none of them will run it seems. I did a fuel pressure test at the shrader valve at the top of the motor on the fuel rail and I get no pressure at all when I turn the key. The relay in the engine compartment seems to be working to as I can hear it. I put a new on of those on to to be sure. Leads me back to the pumps again. I replaced the external pump on the fuel rail and I know thats working. I replaced the fuel filter to while I was there.
Is it possible to have BOTH fuel pumps in the front and rear tanks go at once? Seems unusual. My other F150 with dual tanks worked great and when the back tank pump went I could just switch it over to the front tank.
Well I am ready to drop both tanks and replace both pumps but I would love so experience and input before I go through the time and maybe unnecessary expense.
Thanks Guys!
Ken
Thanks Guys!
Ken
Solved it....
Lesson learned. Hope others learn from this. Ill be back!
Thanks for the responses.
Ken
tommyleea
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
08-14-2019 09:35 AM
JoeFord94
06-24-2019 01:23 PM
vacuumbed
07-16-2014 04:24 PM
BOAZTOBALCAIN
02-26-2003 10:18 PM
