exhaust manifold to header leak
having problem with exhaust leak where the headers meet the manifolds on my flathead 8.
it seems the gaskets available (ford P/N 9450) has a larger ID than my manifold. The bolt pattern is identical, however the inner ID is too big and casues a leak.
Any suggestions...............it looks like there may have been a smaller pipe at time, as the part no. is 9448. But can't find anyone who stocks them.
If you are looking at the parts CD, it's confusing. The gasket set 18-9433, is described as having (9) 18-9448-A gaskets. The same gaskets are used at the manifold-to-block and exhaust pipe-to-manifold joints. The only listing for 9448 is something for the later Y-blocks. FelPro sells a set of exhaust gaskets under p/n MS 8028 B. Advance and others carry it.
The stock exhaust pipes I've seen had a short spigot that went inside the manifold to seal the gasket from the gases. Does yours have that?
Yes my header pipes do have a small spigot as you describe. I will trot on down to my auto parts store tomorrow and order up a set. I am just tired of that P.I.A. of an exhaust leak.
you know, of all the forum sites I belong to the Ford Forum, hands down is the best for getting quick and accurate responses.
Thanks.
Thanks.
ap123363
05-22-2015 01:26 PM
reifwj
04-23-2008 08:31 PM
