Dipstick question
Old 10-23-2015, 03:54 PM
Chasm*18's Avatar
Chasm*18
Chasm*18 is offline
Dipstick question
Hi,
I have an '86 F150 with a 302, 4WD and an AOD.
I checked my transmission fluid level and noticed that the dipstick called for Dexron II. I am wondering if someone put the wrong dipstick in, as I would expect it to call for Mercon.
If so, does someone with my set up have a dipstick that they can measure the length and position of the fill marks? If I do indeed have the wrong dipstick, I'd like to just scribe some new marks if the ones on mine are wrong.
Thanks!
Paul
Old 10-23-2015, 05:08 PM
Franklin2's Avatar
Franklin2
Franklin2 is offline
Received 1,678 Likes on 1,356 Posts
The book I have says your transmission does take dexron II up to 1988 when it changed to Ford Mercon. Most oil you buy now is both Dexron and Mercon. They make a semi synthetic now called Dexron VI, and is the top quality oil to use if you want the best. It's backwards compatible with all the older trannies that took dexron, and it mixes ok with any old dexron left in the tranny.
Old 10-23-2015, 06:44 PM
Chasm*18's Avatar
Chasm*18
Chasm*18 is offline
Thanks, Dave. I already bought a case of Mercon V (found a good price on Amazon). Is that going to work?
Paul
Old 10-23-2015, 07:39 PM
Chasm*18's Avatar
Chasm*18
Chasm*18 is offline
I found a Ford TSB that recommends Mercon V for my truck.
http://www.aa1car.com/library/ford_tsb_06144.pdf
Thanks again for your help!
Stokes
Oil & Lubrication
05-16-2013 05:49 AM
EXv10
06-16-2009 03:44 PM
wmiller
07-11-2008 08:24 PM
SchwinnTruck
1997 - 2003 F150
03-26-2007 09:30 PM
Simon2
Escape & Escape Hybrid
11-05-2003 10:46 AM
Quick Reply: Dipstick question
