K and N air filter question?
Hello all. I have ran a K and N air filter in all my vehicles. Except my 2012 Ford F-150 stx 5.0 liter. Because the dealer didn't recommend it. Does any body have this filter in their truck? And have you had any issues? I would really like to put premium products in my truck. Thanks!!!
I have it in my 2014 ECO...
But get this... The dealer didnt recommend it because they said the oil would cause the sensor to go bad...
So I opt'ed to get one of their special filters...that they recommended...AND IT WAS OILY'ER THAN A K and N... I TOOK IT OUT AND PUT A K and N in... I had one on my 2011 as well....NO ISSUES... You just have to remember that it only takes a very little oil to make it work..MORE OIL IS BAD...LESS OIL IS GOOD
- increases the likelihood of oil contaminating the MAF sensor.
*Over time even minute oil contamination decreases power and MPG.
When it's REALLY EXCESSIVE it will be intuitively obvious.
. - any increase in CFM comes at the expense of filtration.
. - cleaning is a PITA. *And, Yes, I've done it on MAS equipped vehicles.
. - Motorcraft, OEM air filters ...
- meets|exceeds engine air intake CFM requirements.
- good for 30,000+ miles (depending upon conditions).
- ABSOLUTELY NO possibility of MAF sensor oil contamination.
- dispose and replace maintenance.
-click- the pic'
Goth 150
< This space intentionally -blank- >
I've used them in the past in other vehicles but have opted not to use in my truck.
Here is the why....the vehicle is engineered and programmed to take in and utilize a certain amount of air. No air filter will change that. The stock motorcraft filter will flow more air than the engine air intake CFM requirements.
Thus....what are you really getting with a K&N other than less filtering in exchange for more air flow that your vehicle will not use.
You may have a point in a completely stock, naturally aspirated vehicle. However, what you DO get (and it may come at a cost of filtration quality) is a reduction in restriction. I have had a turbocharged vehicle for the last 8 years, and that can make a big difference. Less restriction to air in, less restriction to air out, and tuning changes make HUGE differences in direct injected, turbocharged engines. It's less on non-turbo engines, but it still makes measurable differences. Is it worth the time/$$$ on non-turbo engines? I'll let individuals that have them make that call, but on my truck, there is a definite seat-of-the-pants and dyno proven difference.
Good reading........ http://www.nicoclub.com/archives/kn-vs-oem-filter.html
K&N......complete waste of money on a stock road driven vehicle. K&N may actually flow more air.....but it's at the expense of filtering.
IF the factory filter was restrictive and ate up HP and fuel mileage don't you think Ford would have figured that out?
Exactly how much horsepower can one expect to add to a factory stock engine with only a swap from a factory filter to a K&N.....or are you speaking about an increase from whatever turbocharged vehicle you've had for 8 years?
Good reading........ K&N Air Filter Review - Debunking the Myths (and why OEM is better)
Also, intake/exhaust changes are usually done in preparation for other mods like tuning to take advantage of more efficient flows. Doing just an intake and/or exhaust on a non-turbo engine is probably going to result in negligible results. In other words, I'm agreeing with you.
On a direct-injected turbocharged engine (like modern diesels or Ecoboost engines), it's very a different discussion.
I have used K&N filters in the past and was happy with them. In my 98 f 150 I towed at it's limits, and the difference with the K&N filter in hills was very noticeable. There always is a vocal group against K&N I'm not sure why, but my experiences have been positive. I would also recommend looking up how oil bath filters work. They have been used for years in automotive and industrial applications because they filter better with less restriction.
The reason they aren't used from the factory is that they add to maintenance requirements. I think Ford SVT uses them on some of their projects. I know a local Ford dealer that stocks special Mustangs, Shelby's and Rousch and I've seen K&N filters on those. Finally for something factual the truck is a few years old but the test is resent.
1997 Ford F-150 Lariat Restoration - Tune-up and Fluid Change
gDMJoe hit all the points I was going to state (tried to rep.. in rep jail). No need for me to repeat.
The aftermarket will always market their products as "Premium" and try to prove to the general public that they are "better" and justify the up-charge.... but hey, it's your money.
I spent money on my Borla exhaust KNOWING that I wouldn't actually gain any performance, did it just for the sound.
