Connecting Rods: 6.9/7.3 NA vs. IDIT vs. 94-00 PSD forged
Justin you may also want to look at other rods, if you are good enough friends with your machinist to barrow his parts book. My friend has 900hp 460 with rods out of a 250 in line 6 motor. My book says that the 460 journals are close enough to work, but wont tell me length or wrist pin.
Of course if those PSD rods are all good I don't see any issues coming up with those. Justin made all that power on NA rods, if he made enough to brake PSD rods he'd be on the cover of a diesel mags.
anything is possible with enough machine work... im sure about any big block rod could be made to work. Smaller journals though, so would have to grind the crank, could offset for more cubes, then run a shorter rod. Wrist pins are also too small, but could be bored and pins pressed in. Real issues would be the big end is too narrow on the gasser rods. $500 in rods for 1500 in machine work probably isnt that great of a deal....
GREAT INFO!
i suppose the rod length and the wrist pin are identical with the PSD VS the IDIT?
i think if i was gonna do some custom work like this, id be looking at a set of the forged I beams, but thats some mula!!!
another question i have is, with all the block flex in the IDI's at higher HP is it really feasible to do the rod swap?
not trying to go against your grain, out of the box thinking is what makes the world go round.
The PSD rods are ~.130" wider than the IDI rods at the journal end. So you have to narrow them to use on the IDI crank.
While the rods are .130" wider, the bearing is only .076" wider than the IDI bearing. However, the IDI bearing is overly narrow. I snapped one of the old PSD rod bearings into the IDI rod, and it clears the chamfer on the radius side, and nearly comes flush on the other side. There is no reason it wouldnt work.
And will likely be on a case by case basis.
Diesel crankpin fillet radii is critical for strength.
I killed some time the other day trying to find some kind of connecting rod reference for a comparison by dimension. I was hoping to find a rod from one of the more popular gas engines that's close enough. Of course stock gas rods likely aren't strong enough. But the thinking being that a really nice set of aftermarket rods can be had for hundreds instead of thousands. No joy yet though.
GREAT INFO!
As far as the Block flex goes, Im not one who believes there is a whole bunch of block flex going on at higher levels. If a block is flexing enough to pop freeze plugs, your going to crack it right up the middle anyway. I think the ol' freeze plug story is a result of poorly installed freeze plugs, pushing combustion into the cooling system, or a combination of both... But anyway, thats my opinion until we get there again.
Straight Edge on the chamfer, its hard to tell from the pic, but the straight edge isnt touching the bearing, meaning its highly doubtful the radius will interfere.
IDI bearing in the IDI rod.
PSD bearing in the IDI rod.
As you can see, the extra material is mostly on the inner side of the rod, with only a little extra on the chamfer side. I measured the edge to the tang on each, and the PSD bearing was .107", and the IDI was .100".
I think we are in good shape with this, Im going to run a set in the bronco engine.
#28
#30
Here are a few pics of both the IDI bearing and PSD bearing installed on the IDI rod.
Perfect, lets just say this bit me on a VW years ago.
