TCC solenoid plug location - Ford Truck Enthusiasts Forums
Old 08-04-2003, 11:22 PM
Allen90aerostar Allen90aerostar is offline
Allen90aerostar is starting off with a positive reputation.
Hello! Im new to the board! I have a 90 aerostar and it dies when you put it into any gear. Ive read that you can test to see if its the solenoid if you unplug it. Can anyone tell me where the plug is? And will it be able to drive and shift with it unplugged(temporarily of course)?
Thanks for any and all help!
Allen
Old 08-05-2003, 09:19 PM
rclarke rclarke is offline
rclarke is gaining momentum as a positive member of FTE.
The electrical connector for OD and torque converter lockup is located on the drivers side of the transmission in front of the shift linkage just above the oil pan flange. It is a small (3 wire) connector. To disconnect it carefully pry/ pull the connector straight up. Yes, you can drive the vehicle, you won't have OD or torque converter lockup. Check also for a shorted lead on one of the wires, that would activate the tc lockup. I've even seen a shorted lead inside the pan.
Old 08-05-2003, 11:29 PM
Thanks for replying! I disconnected it, and started her up. I put it in gear and still died. Is there anything else I should look for or can do to get her rolling again? I appreciate any and all help!
Thanks again in advance!
Allen
Old 08-06-2003, 01:53 AM
mrshorty mrshorty is offline
mrshorty is gaining momentum as a positive member of FTE.
That tells you that it isn't because of an electrical problem in the TCC solenoid. The TC clutch may still be stuck on. Crud in the valve body or elsewhere in the transmission is preventing the TCC lockup hydraulics from losing pressure and disengaging.
Here's a test, just be careful and don't get anyone hurt. Pick up the drive wheels, start the engine, and drop it into gear. With the wheels off the ground, there won't be any resistance and the wheels should start to spin. If the engine can spin the wheels in the air, but stalls when you push the brakes or otherwise force the wheels to stop, then it is likely a problem with the TC clutch. You'll probably have to take at least the valve body out so you can clean it up real good.
Old 08-06-2003, 08:24 AM
How tough is it to take the valve body out/how do I do it? Thanks for the advice, I will try that later on today.
Allen
Old 08-06-2003, 01:14 PM
I don't think it's terribly difficult, but you won't want to attempt it without a good manual. You can get ATSG manuals for $15-20, or go to the library and find a good transmission repair manual for the A4LD. For reference sake, the valve body is the part the the filter is bolted to.
Old 08-07-2003, 07:02 PM
That valve body with aluminum valves and housing is a bear to remove the gaskets. You must be extremely careful when removing stuck valves in order to not damage them. In my experience when valves stick in a valve body there is some other problem causing particles of trash in the oil. Check the whole transmission. When you pull the pan you will likely find more than the normal sludge in it.
Old 08-07-2003, 09:39 PM
Thanks! I have a local tranny guy I know thats going to do just that. He told me everything that needed to be done, when was exactly what you guys said. I will let you know how it turns out!
Thanks
Possible Fuel Problem? 1992 AeroStar 3.0 ajbremer Aerostar 13 10-20-2015 07:54 PM
'90 Aerostar broken windshield problem nopeda Aerostar 15 03-07-2015 10:48 PM
What size Allen to remove caliper for brake pad change on 2008 Ford Escape V6 2wd zrt600guy Escape & Escape Hybrid 3 10-22-2011 09:28 AM
transfer case filler plug seized-up fjlee 1999 to 2016 Super Duty 5 09-25-2005 01:59 AM
96 Aerostar Evap System pauldee0046 Aerostar 4 04-13-2005 11:17 AM
Tags
2003, 2008, 73, 98, clutch, converter, diesel, expedition, explorer, f150, ford, install, solenoid, tcc, torque, unplugged, xlt
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
