Light Knocking or rattle at initial acceleration
I have a 2006 Lincoln Navigator and I just changed the oil. I recently noticed a light rattle or knocking noise as I begin to accelerate but it goes away. It kind of sounds like my oil pan is empty, but I checked my oil level and it looks normal. I used 7 quarts of 5w-20 as recommended and replaced the oil filter. Is this normal or the beginning of a bigger problem? I have about 93,000 miles on the truck and none of the sensor lights are on.
20-50 is way too heavy for these engines, with the VCT system and all. I'd try 5-30 or perhaps 10-30 depending on the temperature where you are, and max 10-40 if the rattling is still there. Any more than that and the oil will be too thick to properly operate the variable cam timing phasers.
I have 145K on mine and run 5W-20 Motorcraft synthetic blend without any noises. IMO, running the thicker oil masks a problem that will eventually get worse. The previous owner might have run a thicker oil to cover the noise long enough to sell the truck to some unsuspecting person.
20-50 is way to thick for a normal motor , 10-30 is fine i wouldnt run 5-30 even if it was free . if its knocking , my guess is a rod , and cost all deppends on the damage its done to the crank . drop the oil pan and check the rod caps for play if u are wrench savy parts for a bearing are not to bad , crank is 4 bills
