Help Identify Engine
Old 10-20-2015, 09:53 AM
fordno1's Avatar
fordno1
fordno1 is offline
Restoring this 1954 Ford F250. Not sure if the 6 is original or not. I don't think so but I'm not 100% sure. The intake manifold is cast C3. Here are some pictures attached.
Old 10-20-2015, 10:24 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
1954/64 came with the 223 I-6 as standard equipment.
1954/59: Valve cover retained to cylinder head with two studs/acorn nuts. 1960/64: Valve cover retained to cylinder head with 8 bolts.
C3 manifold: Original 223 exhaust manifold part number was replaced in 1963 by C3AZ-9426-A
The 223 manifold is notorious for cracking, NOS no longer exists, used very hard to find without cracks.
Old 10-20-2015, 11:20 AM
fordno1's Avatar
fordno1
fordno1 is offline
That sheds some light. Does the casting number on the block mean anything? Also, what is up with the oil line running to the top of the valve cover. It taps into by the sending unit for the oil pressure gauge. Is this how the rocker shaft was lubricated?
Old 10-20-2015, 03:37 PM
fordno1's Avatar
fordno1
fordno1 is offline
Figured out the goofy oil line. Unfortunately I discovered a minor catastrophe.
Old 10-20-2015, 04:24 PM
38 coupe's Avatar
38 coupe
38 coupe is online now
Looks like a stock 223 to me. Is that a broken rocker shaft?
youngfordkid
21
08-17-2022 11:24 PM
Torrance00
10-13-2016 11:28 AM
austins59
11-11-2010 09:12 PM
socal4t12
08-03-2009 10:08 PM
cheeseheadmike
11-15-2001 05:12 PM
Quick Reply: Help Identify Engine
