'55 panel truck vin question
Hi all, new to the site and I'm hoping I can get some wisdom from someone.
I just got the frame out from under my truck today and was brushing some rust off where I've read the vin is located. Passenger frame rail in front of body mount. After finding it and looking up other vins and dozens of websites I'm not sure if the stamping was just terrible or it's just rusted off.
The only numbers I can clearly read are "5 29194".
There looks like there might be a "v" in front of the 5 and an "m" between the 5 and the 2 but it's not clear at all.
Any help would be appreciated. I've tried to find how to post a pic but haven't gotten it figured yet. I'd like to get started on a thread of the work so far.
Thanks, Scott.
Thanks, Scott.
I'm wondering if it probably isn't a v since the truck had a 292 and from everything else on the truck it's original. Truck hadn't been plated since 1968 when I got it this summer.
I definitely can't make out any other numbers on the frame though. Thank you for the other info though
V= 239
Z= 256
J= 279 Big Jobs
K= 317 Big Jobs
Received 4,132 Likes
on
I've found out that the serial numbers have been stamped on different sides for the 56 depending on where they were build but on my 56 there is a stamping above where the steering box was and another between the running board brackets on the same side, if your cab is still on you might try using a mirror.
I've found out that the serial numbers have been stamped on different sides for the 56 depending on where they were build but on my 56 there is a stamping above where the steering box was and another between the running board brackets on the same side, if you cab is still on you might try using a mirror.
on
