1999 f250 super duty electrical problems help!! - Ford Truck Enthusiasts Forums
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Modular V8 (4.6L, 5.4L)
Log In
Old 10-18-2015, 07:15 PM
Aleeve87 Aleeve87 is offline
Aleeve87 is starting off with a positive reputation.
Ok I'm a mechanic but my experience is with big trucks/heavy equipment and I am apparently in over my head or maybe over thinking this. My truck was shifting in and out of 4wd high just fine but not into 4wd low I did all the normal troubleshooting on this everything checked out including relays etc. when I removed the selector switch I found there was no power to any of the 4 wires except one when the dash lights were on, now here is where I got careless. I got out the power probe and was checking for circuit polarity and may have sent full 12v power through one of the wires after this my dome light flashes and I have no 4wd indicator lights or function at all. If I pull relay number 1 (dome lamp) the flashing stops but doesn't do anything to the 4wd I'm thinking I may have damaged my G.E.M. But don't know how to test it and I can't find a decent diagram. ANY help or suggestions would be great thanks
Similar Threads
Radio does not shut off when doors open clwhitt Super Duty & Heavy Duty 12 12-11-2015 01:25 PM
Starting issue 1994 F-350 7.5l E4OD jekyll_hyde 1987 - 1996 F150 & Larger F-Series Trucks 6 10-24-2015 12:08 PM
Door ajar, dome light working normal scld1354 Super Duty & Heavy Duty 0 03-25-2015 12:06 AM
Dome Light Conversion papazig4726 1973 - 1979 F-100 & Larger F-Series Trucks 3 03-06-2015 06:07 PM
Door Ajar Light Problem- IT AINT THE SWITCH! Critterhunter Ranger & B-Series 30 12-13-2014 04:36 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Advertising - Terms of Use - Privacy Statement - Terms of Service - Jobs
vbulletin Admin Backup
