E4OD Limp Mode
I just picked up a Flareside F150 w/ 5.8L, AOD, 4X4 & the OD light is blinking (didn't notice a pattern), the Spedo & Odo aren't working, and it has a hard 1-2 & 2-3 shift as well as no 3-4 (OD) shift.
Any thoughts? Sorry for hijack no one has responded to my post. Thanks.
Why, maybe bad fuses if the Odo is not lighting up.
If the Odo is lighting up maybe no input VSS train to the PSOM.
In other words you could start a new Thread with more information.
Just wanted to be clear on a couple of things...for the Mercon V fluid, I am looking for a label that just says "Mercon V" and not mentioning Dexron III like I have seen in the past, correct?
Is it OK to mix the older type Dexron III / Mercon with the newer Mercon V in my transfer case? A good amount leaked out when I removed the drive shaft but I wasn't planning on cleaning out the transfer case to get all the old stuff out
I've never seen a fluid that says DEXRON III / MERCON V. I don't think one exists.
Yes RIKIL, to answer your question .
Use (insert image of bottle of Mercon V)
Rather than (Insert image of bottle Dexron III/Mercon)
Yes, they will mix. Just like if you mix synthetic oil with a conventional oil.
Hope this helps
I am having this exact problem with my ‘90 F350 7.5L (245k mi) w/E4OD (140k mi).
A little background, There has been a idling problem, I replaced the Distributer because the sensor threw a code and I idle control valve which has helped a little. The current E4OD is a Jasper Reman and this trucks 3rd trans. Over the last couple of years the trans would have a slip or shift issue where I would need to let off the gas to get the transmission to shift up a gear when accelerating or whatever.
Well a week ago I topped off the ATF (1qt low and needed servicing) and drove 20mi back home with it unloaded. About a mile from home, after stopping at a light I hit the accelerator and proceeded to go up the hill side when it suddenly had some kind of pop/jerk or something. My truck started slowing down but was still moving up this hillside very slow (I have never been able to my Truck to go above 30/35mph since). I stopped and checked everything. There wasn’t anything out of the ordinary, all the fluids and oil were normal. From there I was able to limp or limb it a mile home.
The next day I checked for codes and got 11, 41 and 67. After which I cleared them by disconnecting the battery for a few mins. From there I serviced the Transmission, replaced the MLPS and after went for a test drive which didn’t make a difference. Over the last week I have been reading a lot of your replies and others as well. After all the reading I replaced the TPS and cleaned the contact connectors on transmission and other sensors too. I keep checking for codes after test driving it, but nothing comes back except for 11. I pulled the ECU and checked the inside for anything loose, nothing appeared wrong. I took another test drive last night after replacing/cleaning/checking everything on the trans. At first it kind of worked, then after about 1/4 of a mile it was back to where it was before, having a hard time doing anything and still in the limp mode.
What am I missing here!?!
Donald
P.S. Thank you in Advance!
A little background, There has been a idling problem, I replaced the Distributer because the sensor threw a code and I idle control valve which has helped a little. The current E4OD is a Jasper Reman and this trucks 3rd trans. Over the last couple of years the trans would have a slip or shift issue where I would need to let off the gas to get the transmission to shift up a gear when accelerating or whatever. Once in a great while it would have a shutter while cruising on the highway.
Well a week ago I topped off the ATF (1qt low and needed servicing) and drove 20mi back home with it unloaded. About a mile from home, after stopping at a light I hit the accelerator and proceeded to go up the hill side when it suddenly had some kind of pop/jerk or something. My truck started slowing down but was still moving up this hillside very slow (I have never been able to my Truck to go above 30/35mph since). I stopped and checked everything. There wasn’t anything out of the ordinary, all the fluids and oil were normal, nothing was leaking underneath. From there I was able to limp or limb it a mile home.
The next day I checked for codes and got 11, 41 and 67. After which I cleared them by disconnecting the battery for a while. From there I serviced the Transmission, replaced the MLPS and went on a test drive which didn’t make a difference. Over the last week I have been reading a lot of your replies and others as well. After all the reading I replaced the TPS and cleaned the contact connectors on transmission and other sensors too. I keep checking for codes after test driving it, but nothing comes back. I pulled the ECU and checked the inside for anything loose, nothing appeared wrong. I took another test drive last night after replacing/cleaning/checking everything on the trans. At first it kind of worked, then after about 1/4 of a mile or warming up it was back to where it was before, having a hard time doing anything and still in the limp mode. I just checked the computer and 11 is the only code coming up.
This is getting very frustrating! Any ideas?
#28
#30
