Trailer Brake Control
Old 10-17-2015, 06:00 PM
HALO1's Avatar
HALO1
HALO1 is offline
Can I add a factory trailer brake control to a 2014 f150 that didn't come with in installed with out to much trouble?
Thanks
Old 10-19-2015, 06:40 AM
'78F250351m's Avatar
'78F250351m
'78F250351m is offline
Did your truck come with the tow package? If so, then yes, it's fairly easy. Order one online and watch a few videos of installation on youtube. It might take you an hour once you start.
If you'd like some more info..you can search the threads on this forum. There are a few with the same topic and more instructions
Old 10-21-2015, 06:52 PM
ford390gashog's Avatar
ford390gashog
ford390gashog is offline
The hardest part is finding a dealer to activate it for a fair price. I had the remote start and brake controller activated at the dealership for one price. They charged me one hour shop time.
Old 10-21-2015, 10:10 PM
xr7gt390's Avatar
xr7gt390
xr7gt390 is offline
The install is easy if you have a factory tow package. If you do not have the factory tow package, you will need to run the additional wire to the back of the truck.
As stated above a reflash is required. Call a few dealers, it seems the prices vary widely on this.
Old 10-22-2015, 01:20 AM
ford390gashog
Gt390,
I thought the harness was the same? Only harness that is different is where it splits by the spare tire. All other wiring should be there.
Old 10-22-2015, 01:32 AM
xr7gt390's Avatar
xr7gt390
xr7gt390 is offline
If you don't have a tow package you will be missing a couple wires in the harness. If I remember correctly you need the reverse wire, the charging wire and the brake controller wire. I think you will also be minus the fuses under the hood. You'll have to install the fuses & run the wires to the back of the truck.
Old 10-28-2015, 04:34 AM
hammer65's Avatar
hammer65
hammer65 is offline
I had a 2012 bare bones XL. Ordered a controller, and the wiring harness that goes from above the spare tire to the 7Pin plug. everything was fine, but there was 1 wire missing, that went from the firewall plug to the rear. tech ran another wire, and it worked fine. I installed the unit in the dash, and plugged it in.
There are a lot of post on this subject, so google it, and you will find a video, on how to install.
Glenstr
2015 - 2020 F150
15
02-11-2016 10:57 AM
hammer65
2009 - 2014 F150
09-17-2013 03:53 PM
ADub98
2009 - 2014 F150
06-21-2011 05:55 AM
JOE BELL
2009 - 2014 F150
04-19-2011 02:56 PM
Scriv
1999 to 2016 Super Duty
05-06-2009 09:05 AM
Quick Reply: Trailer Brake Control
