1955 F100 Driveline and suspension Recommendations
My wife and I just recently purchased a very solid 55 F100 Custom cab pickup and we are starting to brain storm about it's restoration. I will be restoring the truck myself as that is my profession. The truck will be my wife's toy since I already have a few and she wanted something of her own.
The truck has been parked for 30+ years and was just recently woke up from it's sleep and though it needs a lot of attention it runs and was able to drive and somewhat stop on it's own. The current driveline includes a 1966 Thunderbird 390FE with C6 auto and a 9" ford rear out of a torino but I'm not sure what year.
Goals for the truck will be a show truck but it will be driven. No trailer queen here!
We want the truck to ride nice with a low stance on a good looking set of wheels 17-20" most likely. I would also like to get as much width on the rear as possible. If I can get a decent size on it without tubbing that would be fine but if tubbing is needed to get a respectable wheel and tire out back I am ok with that.
We also would like power steering and 4 wheel power disc brakes.
Driveline will require an overdrive automatic and EFI for ease of use for my wife.
The possible engine candidates:
Rebuild 390 FE and use an aftermarket EFI system.
I have a late model GT500 and I have a FRPP 5.4 shortblock as an extra engine that would need a couple pistons replaced from a lean condition the 500 had at one point. Also a lot of other expensive parts to complete most of the longblock/engine assembly.
Final and most favorable option would probably be a late model 5.0 coyote engine and Auto trans.
I recently restored a 52 F1 on a TCI Chassis with a 2010 crown Vic 4.6 2V and 4r70w.
I am also not a stranger to Mustang II front ends and aftermarket 4 link style suspension. However this will be the first 55 I have tackled and could use some tips, advice, opinions, and personal experience.
Well it sounds like you may have some money, so if you can afford it, I would look at a complete chassis from any one of the many builders. It would give you everything you are looking for and get your wife's project off to a fast start which means a quicker finish, which will be better for you in the long and short run.
Thanks for the replies guys!
Dave- I wish I had money! I'm more toy rich than anything but it sure helps to be in the business and be able to do the work yourself. This project will take some time but I like to keep the ball rolling on all my projects little by little. Unfortunately my "baby" my first car a 1970 Mustang Mach 1 I restored in college got rear ended at a stop light this spring so I also get to repair that one this winter.
Jack- 10 inches doesn't sound too bad. The truck may not need a wide tire for traction purposes but it looks good and I like a deep lip on my wheels if possible.
By the way my name is Greg. I tried to edit my profile but I was having trouble getting my name to display.
Greg, sorry to hear about the Mustang. I my first car was a Pontiac that came from my hometown of Le Mars,Ia, not far from you. But my first "baby" was a '69 Mustang Sporstroof, owned it for more than 20 years, made several magazines and the cover of CarCraft in the early '80's. Like you, toy & tool rich after collecting for 40 years. I have several irons in the fire and try to keep them all at least a little warm. If we just keep plugging along hopefully the projects get down before we are done.
Dave, thats pretty awesome! I've also been fortunate enough to have my car make the cover of mustang magazine and a couple other rides I was lucky enough to build make some magazines as well! I need to get back to the cities for the newest version of Car Craft which is now the street machine nationals since Car Craft summer Nats made a move to Wisconsin.
Welcome to the forum! Personally, I'm a fan of using the stock chassis and modifying it, if going with updated suspension. If it were me, I'd seriously consider this...
HEIDTS SUPERIDE II 55-59 Chevy, 53-56 Ford Pickup IRS Independent Suspension - HEIDTS
It's a little more money than the typical MII kit, but worth it both for simplicity and function. It's plenty showy, too. Check their catalog for matching rear stuff.
Aftermarket rear fenders are available wider than stock to allow for fatter rubber, fyi.
Best of luck with your project. I like it.
Do They offer a wider fenders in steel? I know the fiberglass ones are prone to spider cracks from stones being thrown from the tires.
Update... Spent some time on the truck today. I got a better look under it and tried to see if there was a tag on the rear end. There was not but it appears that the rear end isn't a 9" after all. From what I could find on the internet it looks to be a 9 3/8". At this point do I scrap the works or just the center section and axles? Is the housing still usable or not worth using?
It's been a while since my last post and a lot of things have come up along the way. Im still working on the restoration rebuild of my 70 mach 1 and that project has really snowballed. I have also moved to a new house and had my first kid so things have been busy. I sold the engine and trans out of the 55 so that is no longer a possibility. I also have a few people interested in purchasing my stock chassis but I'm no sure what to ask for it. Any ideas on a price? I think if I can sell the stock chassis I will probably purchase a rotisserie to keep it mobile and help in my restoration. I will probably use the cab and the front clip with most everything else being new. I also have a set of 04 mustang bucket seats that I have from another project that I may use for the truck.
truck drive line build
I went a 1997-2000 Explorer rear--had 3:26 gears--disc brakes, TCI spring kit-- Explorer original sway bar-- Lokar emergency brake cables for original hand brake and explorer rear set-up,--I use HEIDTS front Mustang II suspension with power rack-- I use 90's Mustang GT engines roller cam I convert them over to carb, mech fuel pump-- use C-6 trans with the small bell housing a GREAT handling, safe ride and gets up and moves
