oddball transfer case
hi. it's been awhile since i posted here, but i ended up picking up an oddball truck... body is from a 1977 f250 diesel, but the drivetrane is half ton. i am trying to figure out what transfer case it has as it is not a np203 or 205. it only has 2 settings, 4wd and 2wd. no high or low range. it has the 300 i6 (or 240 possibly, but looks like a 300) and 4 speed granny tranny. the chassis is basically a mystery as far as year but appears to be a ford 9 and dana 44.
hi. it's been awhile since i posted here, but i ended up picking up an oddball truck... body is from a 1977 f250 diesel, but the drivetrain is half ton. i am trying to figure out what transfer case it has as it is not a np203 or 205. it only has 2 settings, 4wd and 2wd. no high or low range. it has the 300 i6 (or 240 possibly, but looks like a 300) and 4 speed granny tranny. the chassis is basically a mystery as far as year but appears to be a ford 9 and dana 44.
1966/76 F100 4WD's have coil spring front suspension as do 1975 and later F150 4WD's except 1978/79 F150 4WD Super Cabs.
Could be a Dana 21. Single speed job used by Ford '62-'73, so says this sometimes questionable source:
Transfer Case Basics - FORDification.com
Pic, note Bronco reference:
http://www.66-77bronco.com/wp-conten...1949139170.jpg
GaRedneck91
17
12-30-2014 10:27 AM
Rulebreaker
03-04-2011 10:40 PM
2Wise4aGM
05-14-2002 02:53 AM
mcrank
08-18-2001 11:04 PM
