4.6 hesitation when cold?
4.6L hesitation problem solved
This hestation problem ended being a bad Differential Pressure Feedback Exhaust (DPFE) sensor. Apparently it showed no flow and the EGR opened more to increase flow, thus causing a hesitation with the motor. For 2 years I never had a code set, but finally did and it pointed to the DPFE. I changed it and the hesitation problem disappeared.
Ford has redesined the DPFE sensor, so the replacement looks different from the old. You will find the sensor on the drivers side near the firewall attached to two small tubes that rise from the exhaust. It costs $31.
Hope this helps someone out.
dieterschmied
04-19-2011 08:15 AM
2000, 2005, 46, 46l, cold, expedition, f150, ford, hard, hesitates, hesitation, hgesitation, stalls, starts
