1996 F150 CRUISE CONTROL - Ford Truck Enthusiasts Forums
Old 02-17-2002, 04:04 PM
WB9PRG WB9PRG is offline
WB9PRG is starting off with a positive reputation.
1996 F150
The cruise control was "intermittent" for a few days, and then it finally went out. I have checked the brake switch, and all connections. I have not removed the steering wheel yet.
If anyone has advice please send it to me.
Thanks,
Gene
1996 F150 4X4 Extended cab 153k miles. runs like new... except for the cruise.
Old 02-17-2002, 06:46 PM
carlos57 carlos57 is offline
carlos57 is starting off with a positive reputation.
Did you check your fuses Gene? I had one fall out and the cruise went bezerk. Also check your vacuum lines.
BTW call here is K9ZM.
73
Carlos
Old 02-17-2002, 07:51 PM
slave2dafords slave2dafords is offline
slave2dafords is starting off with a positive reputation.
has anything else quit working?? mainly the horn or do you have an airbag light on?? it could be the clock spring under the steering wheel.
Old 02-17-2002, 08:10 PM
Thanks for the e-mail.
Everything is working fine, except the cruise is not working.
I checked every fuse in the box in the cab.
There is a fuse box in the engine compartment although the fuses are not marked.
One of my friends had the cruise go out on his f150 and the problem was below the air bag on the steering wheel.
The cruise that I have has no vacuum lines and is totally electronic.
Thanks,
Gene
Old 02-17-2002, 09:37 PM
i would say its the clock spring then. MAKE SURE YOU DISCONNECT THE BATTERY BEFORE TAKING THE AIRBAG OFF........ an ex co-worker was messed up pretty bad by one going off in his face.
Old 02-21-2002, 08:32 PM
orange peel orange peel is offline
orange peel is starting off with a positive reputation.
Old 02-22-2002, 02:44 PM
Got it fixed !!!!
The cruise was not working, but everything else was ok.
I checked the fuses. fuse 13 and fuse E were ok.
I checked the Brake switch on the brake pedal. It was ok.
I checked the redundant brake switch on the master cylinder. It was ok.
I took the servo out (2 bolts and disconnect the throttle attachment). Took it to a junk yard near my house. The junk man had a 92 F150 in the back of the junk yard. We pulled the servo off, and installed it on my 1996 F150. He charged me $75. Works like new.
Thanks for the help.
Gene
1996 F150 extended cab 4x4
Rosco2 jesau 1987 - 1996 F150 & Larger F-Series Trucks 6 07-30-2016 09:21 PM
Cruise Control on Conversion kountzecobra 1968-2013 Full Size Vans 6 01-28-2016 06:10 AM
non airbag clock spring? jordan1996 1994.5 - 1997 7.3L Power Stroke Diesel 1 06-17-2015 08:31 PM
ignition timing juju_49 Ford Inline Six, 200, 250, 4.9L / 300 10 10-26-2006 08:02 PM
1991 F 150 Cruise control Adam Kemmerly 1987 - 1996 F150 & Larger F-Series Trucks 6 04-15-2004 04:48 PM
Tags
1996, control, cruise, f150, servo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
