DayTime Running Lights disabling
Old 10-15-2015, 09:21 AM
surreyboy's Avatar
surreyboy
surreyboy is offline
Can anybody out there steer me in the right direction to disable or find out how to disable my factory daytime running lights on my 2015 F350 ? i have installed a set of Recon projectors with Haols & LEDs & want to have just the Halos & LEDs as my daytime running lights & have the factory(now the projectors) disabled so that once i turn the switch on the dash to "on" or "auto" my headlights will turn on(the projectors) and the "Halos" & "LEDs" will turn off
thanks for any advice and or help
Old 10-15-2015, 09:34 AM
Just Strokin's Avatar
Just Strokin
Just Strokin is offline
I responded to this on your previous thread. Was it deleted or did you forget where you posted it?
http://www.thedieselstop.com/forums/...abling-541794/
Old 11-01-2015, 11:02 AM
Lonewolftx's Avatar
Lonewolftx
Lonewolftx is offline
Wink In Manual . . .
I am pretty sure this process is laid out in the manual, it is at least for my 2016 . . .
Old 11-01-2015, 11:14 AM
Just Strokin
2015 and older is a dealer only setting in the SJB. Requires the dealer to hook up to the OBDII port with their computer.
After looking at the 2016 owners manual, I do not think it is owner selectable. I think it still has to be activated or deactivated by the dealer.
Old 11-01-2015, 11:32 AM
Lonewolftx's Avatar
Lonewolftx
Well?
On page 73 of my 2016 manual, DRL there is a 4 step instruction for switching them on so I'm guessing they can be on or off.
Old 11-01-2015, 03:04 PM
Just Strokin
From 2016 Owners Manual
DAYTIME RUNNING LAMPS (If Equipped)
WARNING
Always remember to switch your
headlamps on in low light situations
or during inclement weather. The
system does not activate the tail lamps
and may not provide adequate lighting
during these conditions. Failure to activate
your headlamps under these conditions
may result in a collision.
The system switches the headlamps on
with a reduced output in daylight
conditions.
To switch the system on:
1. Switch the ignition on.
2. Switch the lighting control to the off,
or parking lamp position.
3. Disengage the parking brake.
4. Make sure the transmission
lever is not in position P.
Only a Fleet order can get DRL initialized at the assembly plant
2016 Order Guide
2016 Super Duty Chassis Cab order guide 5/13 - Diesel Forum - TheDieselStop.com
See Page 12
LPO/FLEET OPTIONS (Requires Valid FIN Code) (see Packaged Options/Emissions pages for complete content and restrictions on
packages) Ambulance Prep
DRL has a code F
Old 11-02-2015, 11:38 AM
Lonewolftx's Avatar
Lonewolftx
That's it . . .
Like I said I thought I saw it in the manual. Hope it works out for them . . .
Old 11-02-2015, 12:07 PM
Just Strokin
You can get a dealer to turn them on....well most dealers will
might need to take this bulletin with you
https://www.fleet.ford.com/truckbbas/non-html/Q175.pdf
I know the 2016 Fusion I have on order will let the owner turn the DRL's on or off. Maybe the 2017 will also when it is released next year.
basketcase
1983 - 2012 Ranger & B-Series
07-25-2017 08:42 AM
Hummer1
Escape & Escape Hybrid
07-18-2011 09:44 PM
dhag911
General Automotive Discussion
10-20-2006 09:39 PM
10er350
1999 to 2016 Super Duty
03-27-2006 04:57 AM
rayway
2004 - 2008 F150
18
03-20-2004 09:44 AM
Quick Reply: DayTime Running Lights disabling
