2000 F250 5.4l loss of power
Hello,
I recently bought a 2000 f250 XL with the 5.4l in it. I has very little driving power, and the power is starting to surge. The truck will slowly get up to speed and will reach roughly 75mph but nothing more. Also with towing i cannot reach 55mph. the engine light is on and is throwing a bank 1 lean run code.
Here's what i have done so far:
New spark plugs
New fuel filter
New fuel pump
2 New fuel injectors i believed were bad
2 new coils that i also believed to be bad
Checked for vacuum leaks
Cleaned throttle body
Cleaned mass air flow and air filter
changed one of the upstream 02 sensors
Im at a loss at this point, and have no clue what to do next. any help or suggestions would be greatly appreciated! thanks
New spark plugs
New fuel filter
New fuel pump
You will be a lot better off if you stop guessing and get the proper tools and TEST to see what is wrong!!!!
CaseyLandscapes
16
12-01-2013 01:32 PM
