88 Ranger NO SPARK - Ford Truck Enthusiasts Forums
88 Ranger NO SPARK
Old 08-04-2003, 06:51 PM
kevinswart kevinswart is offline
kevinswart is starting off with a positive reputation.
88 Ranger NO SPARK
Hey Guys,
I just bought an 88 ranger last week it is 2wd 2.3ltr. It was running great, yesterday I changed the oil, when I started it afterwards it ran for about 1 minute and stopped. Fuel pump is working, I checked at the coil and have no spark. This morning I replaced the coil and wires... Still no spark... I talked to a mechanic friend of mine and he said it sounds the the control is gone and told me to hook a test light to the leads on the coil and one should be lit constant and the other off and on.. Did that red side was solid but nothing on the green. So I changed the control module... STILL NO SPARK!!! So far today I have about 5 hours and $60 worth of parts and no results... Also still nothing on the green wire going to the coil.. Also disconnected the battery to try and reset the computer and that didn't do anything either Any suggestions or ideas? This truck is driving me crazy....
Thanks,
Kevin
Old 08-04-2003, 07:11 PM
Bob Ayers Bob Ayers is offline
Bob Ayers has a good reputation on FTE.Bob Ayers has a good reputation on FTE.Bob Ayers has a good reputation on FTE.
88 Ranger NO SPARK
First, welcome to FTE!!!!
It sounds like you have a bad coil. Without the engine turning over, you should have 12V on both coil terminals.
Old 08-04-2003, 09:58 PM
88 Ranger NO SPARK
Well it's running.. I decided to disconnect both battery terminals and let it sit for a while. Tried it about an hour later and it started right up.... I'm hoping it was just the computer needed rebooting... Thanks for all the help!
Kevin
Old 08-05-2003, 12:24 AM
bjmyers bjmyers is offline
bjmyers is starting off with a positive reputation.
88 Ranger NO SPARK
I'm having the same problem with my 86 ranger, you think the same thing would work with mine?
Old 11-04-2003, 09:51 PM
Xoryx Xoryx is offline
Xoryx is starting off with a positive reputation.
Hey fellas. I really need your help here. My truck has been sitting for entirely too long. Even for a FORD ! I haven't been able to start it for a month now. I can't get a spark from the ignition coils to the plug wires.
It's an 89 Ranger 2.3L EEC-VI DistributorLESS Ignition System. Dual coil packs are both new and working properly. New control module. Fuel pump works perfectly. Have done numerous testing of relays and for shorts. I have extracted the engine codes: 15 and 212
15 is EEC processor ROM test failed.
212 is Loss of Ignition Diagnostic Monitor (IDM) input to ECA/SPOUT circuit grounded
I am not quite positive about the 212 code.
Using my Analog meter the sweeps were in this pattern: II II I II II Am i reading the code wrong?
As I turn the key the starter cranks the engine, but no spark! I know that the Cranksaft position sensor works fine.
The whole senario started when the secondary igition coil was not firing while the engine was running. I replaced the coil. no change. Then i removed the DIS module to have it tested. It passed the test and i put it back on. I have never been able to start the truck since.
I am using the basic Haynes manual which has been usful to a point. But now i think i need some experiential help.
What are the codes REALLY pointing to ? Do i need a new Electronic Control Assembly?? I would appreciate any well thought out guidence to help fix this truck and get it back on the road.
Thanks, Xoryx
please help me find my spark problem nojoke327 Expedition & Navigator 4 04-10-2014 09:41 AM
no spark badignition 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 24 11-11-2013 08:56 PM
5.8 No Spark or Fuel Pressure 93E-150 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 9 03-29-2010 06:26 PM
390 No Spark? Help Please!!! tjs_79ford FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 11 09-20-2009 12:30 PM
88' Ranger:Stalled & now no start, seems like no spark G2IC_Wraith Ranger & B-Series 17 09-30-2007 12:06 PM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
23, 23ltr, 86, 88, 88ranger, 89, coil, conditions, cylinders, dis, ford, fuel, module, ranger, spark
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
