General Automotive Discussion
Replacing Antifreeze with Spent Oil Experiment
Old 01-22-2016, 12:19 PM
grasfarmr73's Avatar
grasfarmr73
grasfarmr73 is offline
How do I tell which cylinder it might be?
Old 01-22-2016, 12:25 PM
nitrogen's Avatar
nitrogen
nitrogen is offline
Pull the spark plugs and look for and odd looking one
Old 01-22-2016, 12:29 PM
Tedster9's Avatar
Tedster9
Tedster9 is offline
^^^ It will be noticeable
Old 01-28-2016, 04:28 PM
Pele's Avatar
Pele
Pele is offline
Run the engine until the cooling system pressurizes, then shut it off. Pull the spark plugs and set rags on top of all the holes. Crank the engine. The leaky cylinder will have coolants spray out of it, or in this case, oil.
Also, how're those radiator hoses holding up to oil? Rubber doesn't like oil too much.
Old 10-17-2016, 10:59 AM
grasfarmr73
This experiment has ended. The car was pretty gross this spring from being having cats live on it when it was under the roof so we just shoved it outside where it sat until Saturday. It's getting hauled off for scrap.
We had a Bonneville (Cleansing the place of GM influence ) on the trailer already and had to make the Star Cruiser smaller if it was going to fit on the trailer with it.
I'm sure Grampa was laughing from upstairs at what would follow.
1st, another experiment. What happens when you drop the back half?
Old 10-17-2016, 11:10 AM
grasfarmr73
Time for hydraulic power.
The result:
Since this is a Ford truck forum...
Old 10-18-2016, 10:08 AM
Pele's Avatar
Pele
Pele is offline
Booo... Cut it entirely in half.
Route the fuel lines to a 5 gallon bucket in the passenger seat.
It's FWD... Drivetrain is all under the hood. There's no reason for the car to continue existing past the front seats.
Old 10-18-2016, 01:45 PM
grasfarmr73
Except it was no longer running.
elinmon1976
06-02-2011 09:50 AM
reed1951
02-12-2008 02:05 AM
oldjeep
07-29-2004 10:08 AM
Brother_Owns_A_Ford
08-29-2003 09:19 PM
superswamper
20
08-06-2003 12:18 AM
Quick Reply: Replacing Antifreeze with Spent Oil Experiment
