Replacing Antifreeze with Spent Oil Experiment
Run the engine until the cooling system pressurizes, then shut it off. Pull the spark plugs and set rags on top of all the holes. Crank the engine. The leaky cylinder will have coolants spray out of it, or in this case, oil.
Also, how're those radiator hoses holding up to oil? Rubber doesn't like oil too much.
This experiment has ended. The car was pretty gross this spring from being having cats live on it when it was under the roof so we just shoved it outside where it sat until Saturday. It's getting hauled off for scrap.
We had a Bonneville (Cleansing the place of GM influence ) on the trailer already and had to make the Star Cruiser smaller if it was going to fit on the trailer with it.
I'm sure Grampa was laughing from upstairs at what would follow.
1st, another experiment. What happens when you drop the back half?
Brother_Owns_A_Ford
08-29-2003 09:19 PM
superswamper
20
08-06-2003 12:18 AM
