2007 Escape XLS - No front side marker lamps
Hi all...
Recently bought a 2007 Escape XLS...realized that the front side marker light/bulbs do not work at all (rear marker bulbs turn on with headlight switch)...though both front turn signals do work.
1st...checked the interior fuse for circuit - fuse good.
2nd...Took apart right wheel-well trim and replaced the 3157 Amber dual filament bulb thinking perhaps both marker filament had just burnt out over time. Unfortunately after the bulb change there was no change...turn signal filament works on both sides - front side marker filament(s) does not work.
Anyone have any ideas what I should do next...?
Thanks in advance...William
There are only 3 bulb assemblies in the front end of my 2007 Escape - 1) the headlight - 2) the high beam headlight - and 3) the amber 3157 dual filament bulb I am having the issue with...serving as the parking lamp/side marker light and the turn signal.
I apologize for my end-user lack of proper terminology...!
The
The
Okay, it looks like that side marker lamp is Mariner-only (which is what I have) and I was expecting the Escape to also have it. Sorry about my confusion.
The front parking lamp circuit comes from SJB connector C2280B Pin 8 (brown wire) via splice S118 which is located in the left front corner of the engine compartment near the BJB. The circuit is jumpered internally in the SJB to the rear parking lamp circuit which comes out on Pin 19 (same connector, also brown wire).
Thanks - that is helpful info.
There is a high power 40A fuse in the Power Distribution Box (#23) marked 'Rear defroster, Park Lamps relay'...do these ever burn out...?
Since the rear parking/taillamps come on constant when switched - only the front lamps do not work - where might the likely disconnect in the wiring for both front parking lamps.?
Thanks again...!
Thanks again...!
choate
01-16-2015 05:00 PM
Fastfwd
1999 to 2016 Super Duty
08-22-2013 10:02 AM
RCrawler
07-19-2011 12:08 AM
