1978 - 1996 Big Bronco
1995 bronco problems
Old 10-13-2015, 03:26 PM
Corey Tanner's Avatar
Corey Tanner
Corey Tanner is offline
I bought a 1995 bronco recently. Long story short the guy ripped me off. Engine had rear main seal leak and a lot of other things wrong. I have used this site to fix most of the minor problems. I changed the tps and vss in the rear end. Dropped another rebuilt 302 in it. Now here's my problem recently. When I go down the interstate my speedometer jumpsnaround once I get over 55-60 mph. The abs light comes on and once I get off the interstate my bronco shifts from park to drive and reverse hard and shifts into 1st and 2nd gear hard too. I am in the army and moving to another state soon and in need to get this fixed before I go. Any ideas I can use tonfind the solutions. You guys are awesome and I have fixed everything that I had problems in the past. Hopefully you guys can help out with this. Thanks brothers.
Old 10-13-2015, 04:51 PM
Kemicalburns's Avatar
Kemicalburns
Kemicalburns is offline
well your new issues are unrelated to the engine unless of course the TPS is out of wack. sounds like you may have either a bad rear ABS sensor located on the top of your rear diff or its your 4wabs module located under your window fluid/rad overflow tank..
pull codes and get back to us.
Old 10-13-2015, 07:02 PM
Corey Tanner
Thanks
Thanks for the reply. I Cleaned and changed out the tps a while back. Do you think it could have gone bad again? Are they sensitive?
Old 10-14-2015, 10:48 AM
hivoltj's Avatar
hivoltj
hivoltj is offline
Check the abs sensor in the top of the rear axle pumpkin. We'll known issue on these. It's either going bad or the tone ring is. Pull it out, wipe off the metal shavings put it back in and see.
Old 10-19-2015, 05:52 PM
richard1586's Avatar
richard1586
richard1586 is offline
Corey, I have a set of Ford Dealer manuals that you can have if you will reimburse me the mailing charges. (I would send it USPS Priority but have no idea how much it would cost - figure $20-$30 dollars) I have a 1996 and it is different enough from what I need that I can't use them too much. One book covers engine and the other covers body/frame.
sekyridgerunner
07-16-2014 07:27 PM
Kemicalburns
06-26-2007 01:45 PM
bblgreen
1999 to 2016 Super Duty
08-03-2006 05:25 AM
garymulins
11-25-2002 06:14 AM
kevhard
10-24-2002 03:46 PM
Quick Reply: 1995 bronco problems
