95 Ford e350 7.3 fuel filter housing question
Hello I have a diesel leak on my E350
I looked up schematics for the fuel filter housing assembly
But what I am seeing looks more like what is on my 1999 f250 or 01 f350
Does the 1995 E350 have the fuel drain assembly ?
I know these tend to go bad on my other trucks
I just replaced the filter, with fixed cap model, looks like the prior owner only replace the filter using the old cap and o ring
There was diesel in the front of the housing
filter cap
Thanks for the reply I used a better model made by hastings
The oring is fitted to the cap, is much larger round o ring that has a seat in the cap itself where it cannot move while screwing it in place , unlike the old flat washer caps
When took the old filter off that was leaking the gasket was down inside the bowl. yes poor installer but on my 99 and 01 they cause me trouble as well
Actually the better O-rings have a wedge type profile...at least those are the ones I use ..Racor is the manufacturer...And as far as the 99 and up style goes , I think they tend to leak where the Filterbowl attaches to the HPOP reservoir along as well as the drain O-rings...but a lot of guys with the later PSD's tend to remove the assembly and use an AirDog type set-up or similar remote filter/separator units
Donzi 26 zf
06-15-2006 05:05 PM
