Which oil for a '89 e350 460ci with c6 ?
As pointed out, viscosity depends on outside temperature. Owners manual recommends 3 grades:
5w30 , upper limit 15 degrees C, no lower limit
15w40 Lower limit 10 degrees, no upper limit
10w30 lower limit 0 degrees, no upper limit. It is also listed as the preferred oil.
That being said, as my motorhome is used summertime only, I have been using 15w40 for about 15 years with good results.
Typically change the oil and filter every 5,000KM , or once a year; however if you are running lpg, you could probably lengthen the mileage interval with no problems.
Good luck
Jeff
Good luck
Jeff
Resendiz
09-03-2015 09:36 PM
4inchlovin
01-24-2008 12:25 PM
