I assume its an Electrical Gremlin??
Good morning everyone, and Happy Thanksgiving to my other fellow Canadians!
I'm having some issues with my 1986 F150 that I am at my wits end trying to figure out. To start, its a 1986 F150 XLT, 4x4, 302 (5.0L) EFI, Auto trans, with 110,000KM (68350MI) on it.
The past few days I've been in the shop working away at replacing both valve cover gaskets, upper and lower intake manifold gaskets, replacing spark plugs, wires and cleaning up the rotor and cap, and giving as good of a cleaning as I can do.
So now that its all back together, it fired right up, and purred away while sitting in the shop, and had no issues while I drove it around the compound to warm it up. As soon as I closed up and started driving it home, the truck just died, and wont start again. No coughing or sputtering, the only way I noticed was just because I stopped accelerating. Lights didnt dim, and the radio didnt die, it just stopped running. Now it wont start again. It'll crank and crank and crank, and every once in a while it'll want to catch, but nothing.
At this point, I'm completely lost, and starting to get stressed out because I can't figure out where, or what I'm supposted to be looking at! So any help would be greatly appreciated!!
Cheers!
Cheers!
I've had the unfortunate luck of this happening to me also.
For me it was a bad ground with the DSII system. Engine just shut off. Lights were still on, radio still going, just like you describe. It wasn't grounding properly through the distributor. Spliced into the ground wire from the Ignition Control Module to the dizzy and grounded it to the frame. Haven't had it happen since.
Hope this helps.
Hope this helps.
So I've been combing over the truck, and checking different things. And I think I'm ready to agree with you guys! So I've checked the ground and it seems to be working fine, but I'm going to swap in another distributor to see if that gives me any better results. So far I've been able to get it to fire up and run, but with the throttle as wide open as it'll go before it goes into the flood shut off range (wide open). It'll run, but barely and at a really low grumble... With my work schedule I'm only able to pick away at it now, but hopefully I've started narrowing things down now!
Not really enough info here to even suspect an electrical problem. Engine does not run? Compression, fuel or ignition. Which one is missing? The fact you did get it running suggests the ignition or anything else electrical is likely working. I would suspect a fuel delivery problem, possibly a failing fuel pump. Check the fuel pressure at the rail with a gauge. No shortcuts! Also check codes as has been suggested. If there is something wrong, the system will flag it.
Thanks for your input! As far as I can tell, all 5 components are there. I checked the fuel pressure at the rail, and even hauled the injectors out and cranked it over, and trust me, theres fuel! Haha! It has good compression, is getting air, TPS works, and am getting a nice bright blue spark when the plug is out of the cylinder. Ive checked and retimed it, and thats proper. Wires on the cap are in the correct order, and so far I haven't been able to find any sort of short in the wiring, and no codes are coming up either.... So now I'm entering the stage that I'm running out of things to look at. Maybe a faulty inertia switch or something?
Truckman8719
20
07-31-2018 05:45 PM
eliteman76
12-08-2014 09:40 AM
ErinsFord
02-18-2013 02:48 AM
cowboywanabe
08-24-2002 10:10 PM
