Intake question 302 EFI performance
The other discussion getting pretty full so try again. Many comments showing the truck 302 was better than the 351 stock components and better than the mustangs, generally. I have a 92 currently with speed density 5.0. Question is has there been testing to show that the newer 95 to 97 versions flowing better ? Is it worth trying to upgrade to the newer stock version ? What is needed to do that ? Computer swap ? Plumbing for intake, wiring issues ?
Ok, thanks guys. Just want to make sure I am going in right direction. Found some long tubes for the 5.0 last weekend at the local pull a part, so thinking of doing the cam and exhaust (maybe) consider the gt 40p heads on this one, then take the slow methodical approach with the 5.8. Discovered by using a laser thermometer that my 2 cats on this truck are not working, so perhaps there is some restriction there ? Here's the question on exhaust, since I may use the setup on the 5.8 later, does 2.5 single sound decent, with the long tubes ?
extcab 95flareside
09-27-2012 01:22 PM
joey390burnout
11-12-2010 09:33 AM
petroskie
11-23-2009 05:33 PM
Diggie
09-04-2004 09:20 PM
