crack in 59-ab head can it be fixed?
While cleaning the heads I discovered a large crack between the middle water hole and lower middle stud hole, it also looks like it is traveling toward the upper stud hole. Can this crack be fixed with a plug / weld repair or should I start looking for a new head? I talked to my local machine shop a few weeks ago (before I saw this) and he said cracks are normal in flatheads and depending on the size some don't even repair??? thanks in advance
I replaced a head gasket on a farm tractor recently (actually a 1941 Cletrac crawler). The 4 cyl flathead had a crack in the head identical to the one you have pictured. I did nothing to it and put it back on. The crawler runs just fine, even in hot temps.
I realize a truck motor is different than a tractor motor, so perhaps you are better off getting another head. Just be sure the replacement head doesn't have it's own set of problems.
vandorin123
03-18-2011 01:16 AM
