Bad Computer?
Bad Computer?
I have a 1990 F150 with the 302 engine. It will run for awhile and then shut off, as if you have shut off the key. I replaced the electronic ignition under the distributor and the TPS. No luck. Fuel pump works fine.
I am also getting the following codes: 14, 87, 32, 53
Any ideas?
Any ideas?
Code 14 is the key clue here.....
Code 14 (CM): Two or more successive erratic Profile Ignition Pickup (PIP) pulses occurred.
The PIP (aka Stator) is located inside the distributor. It's the sensor that triggers the ignition. It can be replaced but requires a few special tools. Most folks replace the distributor but be leery of "rebuilt" units because many times they have a bad PIP in them because they were never checked.
For reference: PIP aka Stator
BTW....Welcome to FTE!
oriellys has rebuilt distributors for 99$ and NEW for 89$ .
Computer? They can't seem to tell on themselves if they're going bad.
Easiest is to sniff them for burnt smell, pull the covers and look for leaking capacitors.
Not a bad idea to check voltages TO the computer plug, check grounds etc.
I'm sure I've seen a writeup on here before.
Sounds like rla2005 has been thru this before.
rustfreemike
16
02-26-2014 11:39 PM
